New TunerPro 4.14 build available and more...
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Hello Everyone -
This past weekend I finally got around to releasing another build of TunerPro. You can get it at the web site: http://www.tunerpro.net/
Included in this release:
v4.14.0323 (6/17/07)
I also wanted to take this opporunately to let you know that, in addition to the forums (forum.tunerpro.net), you can join the mailing list for TunerPro, ScannerPro, and related discussion at www.tunerpro.net.
And finally, I've also uploaded a new build of EmUtility that addresses a number of issues related to large binary support.
Thanks for your interest and support!
-Mark Mansur
TunerPro Free & TunerPro RT
- Lots and lots of little stuff, some crashing bugs, plus bunches of stuff I don't remember (been a long time since last release)
- Added indication in each item editor that data has changed
- Added warning when closing an item editor if changes have been made but not committed
- Fixed a copy/paste bug with tables
- Fixed lots of issues with large binary support (Moates Ostrich)
- Fixed issue where COM ports above 9 weren't working w/ harware
- Added ability to import Motorola S records as binaries
-Mark Mansur
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
Re: New TunerPro 4.14 build available and more...
that's awesome mark, i just wanted to say thanks for your work, tunerpro is awesome and your generosity is amazing, keep up the good work! lookin forward to T.P.5!
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
thanks Mark, you ROCK
Car: 69 Camaro
Engine: LS1 converted to LS6
Transmission: 4L70
Axle/Gears: 12bolt 3:42
Mark for ScannerPro is there anything do watch out for like redoing the definitions?
has anybody been able to get scannerpro to connect and work with a $0D code? i would love to get it to work with my 95 truck? tried importing my tunerpro definition and that dont work. also tried using the $0D def from fast355 for maf and i cant connect with that either. thanks
Transmission: T5WC
Its more likely that logs taken from an earlier version won't be compatible with later versions, at least until I finish up the log format.
Car: 69 Camaro
Transmission: 4L70
Mark I installed the new version on a Vista machine -my desktop and I cannot read any old datalogs. I get a 0D error and it says it is unable to read the file. Would you like me to report this or do some more testing for you on this or is this known? My laptop is XP which is where I will do all my datlogging and I have not tested that yet.
Transmission: T5WC
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Great Software. Thanks for the time and devotion for a great tuning piece of equipment.
