730 and tunerpro rt help
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Transmission: T-56 fully built WOOHOO
i have the 8d definition i downloaded off of moates i cant understand the flags/switches it looks completely different than my 6e 165 computer that is cake to understand and disable vats but on this one i just cant understand it
file was called 8d.xdf that is correct for a 730 too right?
this is gibberish anyone have a good definition file so i can actually understand it. i am trying to disable vats, air injection, and egr. or any help would be appreciated.
its for a 305 tpi axxf is a fine bin also correct?
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
Re: 730 and tunerpro rt help
I used the “Super 8dm2.ecu” bin definition file from the Tuner Pro site on a SAUJPv3 bin. I had to have the Tuner Pro program convert the format from “.ecu” to “.xdf”, which it did without trouble.
http://tunerpro.markmansur.com/downloadBinDefs.htm
When you bring up Tuner Pro, you should see on the left of the screen the flags section and the flags for VATS at the top. Click on “bit 4 - VATS” and that window comes up, then uncheck the box. (All the other vats bits are already unchecked.) I couldn't attached the screen shot here...
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i also mainly use Super_8dm2.
if you right click on something & then choose "Edit Item XDF info", it may give you some more info on what that item does.
for data logging i like First Thirdgen.ads, it seems to be pretty complete & works good.
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
Should be switch 16 bit 4. I believe that the check mark enables VATS, so you want to uncheck it.
You can also click "View" and "item comments" to see more information on some things (but I think some comments are wrong). I found that the "anht_hack.pdf" was the most complete and usefull information for understanding 8d. Page 1 "AFR Options Flags" has the VATS info.
Good luck
Good luck
