42 XDF file???
42 XDF file???
hey im just wondering if i have the right xdf file for my 7747?? I went to moates site and downloaded the file that starts with 42. Can anyone tell me if this is the right xdf for the 7747 ecm??? It seems to be right but it also seems to be missing alot of flags and constants. Any help would be appreciated.
Re: 42 XDF file???
Hey thanks for the reply but I cannot seem to find any XDF titles at the tunerpro site. Just ecm files @ bins??? I think I have the right xdf now but the flags and switches are just numeric error codes and checksum code sets, is this normall??? Thanks for the help again.
Re: 42 XDF file???
Ya i did find that file on tunerpro's site but how do you convert it to an xdf so that it can be used with that program??? Any help on this would be great. I can copy and save that file but cannot use it with tunerpro as it does not reconize it as an xdf. How do you convert it when you save it etc. Thanks again.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: 42 XDF file???
in TunerPro hit "XDF" & then "Import", now click "From ECU.." point it to the ecu file.
when you close TunerPro you'll get a pop up asking, "XDF Modified, Save?" tell it yes & set a location for it & give it a name. its now an XDF file.
Re: 42 XDF file???
Hey thanks alot guys for the help!!! I got what i need and know how to do it now!!! Greatly appreciate all your wisdom. Sorry for the little things but just a newb at this!! I need to do a few data logs and I will let you know how the tuning goes. I sure I will need some more help in a while. Thanks once again!! I plan on doing some tuning for a couple months and then ordering the Ebl so that i can go high tech LOL. I think its good to start out simple first right??
