A/D counts
A/D counts
Is there a formula to convert a/d counts into degrees? the 7747 ecu file its in teperature terms, the 8746 ecu file uses a/d counts. I am going to try to use the 7747 formulas in the 8748 ecu file, since i think the a/d counts are a "raw" form.
Car: check
Engine: check
Transmission: check
Re: A/D counts
There is a lookup table in the asdz hac for ADC to degrees C. The response is a S curve, so the lookup table is the easiest method.
There is another temperature term that is linearized. But isn't used too often. Something like = N * .625 - 5
Eric2ndGen
08-31-2015 11:30 AM
