analog output of lm-1
ive been logging my lm-1 wideband thru my autoprom with the apadc a/d hardware from moates with tunerpro rt. everything seems fine. logged a bunch without problems. but i just noticed that the wideband afr coming into tunerpro is roughly .4 -.7 lean compared to whats on the lm-1 display. ive checked the analog 2 ouput in the lm-1 and it seems ok. im using the 0volts =10afr, 5volts =20afr. the factor in my ads. file seems right per the instructions from moates site. im not sure what to check next. thanks
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: analog output of lm-1
I have the same issue, the AFR in the datalog is slightly leaner then the display. Like said above, its probably a bias between the LM1's ground and the ECMs ground. Im lazy, and I pull ground through the cigarette lighter, which probably is slightly biased.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
You could always tap into the ECM ground wire for the WB ground. That's what I did with my dual LC-1's.....
Car: 88 Camaro SC
Engine: SFI'd 350
A dedicated ground between the ECM and the controller is teh best method as stated above.
The display is still accurate, just that there will be an offset in the reported AFR in the datalogs.
TMZIrocZ350
10-07-2015 12:09 PM
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
83 Crossfire TA
09-18-2015 12:01 PM
