no more xdf's at Moates.net?
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Ive been trying all morning to load a $8D XDF file into Tunerpro RT and for some reason the one on Tunerpro's site is a .ecu file? And you now need a password to get to Moates files. What am I doing wrong?
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Re: no more xdf's at Moates.net?
It tells you right on his site to use the following to access the file store:
User = moatesuser
Password = moatespassword
You can also import an ECU file and then save it as an XDF file in TunerPro....
User = moatesuser
Engine: Miniram 383
Oh, OK thanks Vern, I must have missed that.
No problem, glad to help out.
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Keep in mind it also has to be "imported" first before you can open it.
from the top use: XDF>IMPORT>ECU (from where ever you downloaded it to, maybe your desktop, or downloads. If it got lost look for it by putting *.ecu in your your search bar.
There is also an upgraded version around here as a Super $8D file with extended upper rpm tables among other things.
Go here for it.
http://www.edgesz28.com/edgesz28/sup.../Super8ecu.htm
There is groundwork for it here as well.
https://www.thirdgen.org/forums/diy-...rogramming+101
I don't want you to think I understand it all, just that I know where it is. Whenever I find something that will be of future help I bookmark the sites as
favorites.
Go here for it.
favorites.
