16168625 ALDL knock?
Car: 93 astro van
Engine: 350 tbi
Transmission: 4l60e
I can't find anything in the ALDL info for the 16168625 $E6 mask for knock counts. Does any one know what bit is used?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: 16168625 ALDL knock?
Off the top of my head, only the final knock retard SA is transmitted thru the ALDL.
Knock retard is not reported via the ALDL datastream on the $E6 mask but it can be added. In the $0D datastream, knock retard is output in byte 56 of the engine datastream. In the $E6, byte 56 is desired AFR. In the hex editor in TunerPro, if you go to L524F and replace the $6C with $0F and then use the $0D (A217) datastream definition, you will see knock retard in byte 56. HTH
Car: 1998 Camaro Z28
Engine: 5.7 L
Transmission: Manual
I'm curious to know this too... I got my datastream file from another guy on here and it has the knock retard in there already, but it stays at 22 or so degrees. is this just a reference the computer uses to say "this is how much I'll take out if I have to", or does it only give a number when it is actively taking out timing. I also have a stream for "ECU counts from last loop" Is that knock count?
This is an old thread but I hope someone can still help. What is the location of L524F? When I open the hex editor in tunerpro the actual data starts at 00004000 and ends at 0000FFF0 and they all end in 0. There is no L524F. Maybe the program changed since that was posted? I really need to know cause I want to watch for knock.
I found it. I feel really stupid now.
Can I use the $0D ads file for all of my data logging? it has a few things that my $E6 one doesn't like rpm. Does anyone have a newer xdf file for the $E6? The one I have is from Moates and I have another from the tunerpro website and they seem to be missing some things.
RedLeader289
05-28-2019 01:47 PM
bigjay89gta
10-15-2015 08:04 AM
efiguy
09-27-2015 01:30 PM
0f, 16168625, aldl, auto, conversion, data, datastream, ecm, file, program, stream, support, tbi, transmission, xdf
