Newb questions about winaldl datalogging and error codes.
Car: 1988 Chevy silverado K5
Engine: 350 bored .030, crane cams hyd bluprint l-79 cam 447 lift 272 dur, camel hump heads port and polished 1.94 1.50, afterburner headers and y pipe, holley 670 cfm tbi, holley projection dual plane manifold, accel high pressure fuel pump, 3 inch exhaust
Transmission: 700 r4 with corvette servo and shift kit.
Ok I think I'm missing something here... So you can't save your datalog? I can't seem to find out how to save it.
Is the log limited to whats on the "tabs" or is there more to it?
Also I idle at 60 kpa and never get a full log. Is this a problem?
I got a high map error code but I am more concerned about the PROM error code that shows up.
What do these mean? bad map sensor... bad .bin or even worse a problem with my ecm or prominator?
