Looking for more info on the 8192-baud data stream
1 Post
Car: 1986 IROC-Z
I'm looking to learn a bit more about the way GM's 8192-baud data stream behaves. Is there an article that goes over the timings? I took a quick look through one of the hacks and couldn't find any memory locations for the start/stop bit times.
160-baud requires around 6250 microseconds to send a bit... so 8192 would be something like ~120 microseconds, right?
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
The 160 baud aldl is bit banged in software, were as the 8192 baud aldl serial is implemented in hardware. The hardware implementation is interrupt driven from what I can determine.
3rdgenparts
05-21-2016 11:50 PM
Linson
10-01-2015 09:50 PM
