spark knock at WOT
spark knock at WOT
i was running the craig moates scanner on my car logging during a 1/4 mile run and i notice a problem. during the WHOLE run im getting from 5.5-8.5 degrees of spark retard due to knock. the problem is my timing is dead on 0 degrees TDC, and my o2 sensor was reading ~.900 mV the whole run so i wouldnt think im running lean
its a 89 iroc L98 ported stock base, stock chip
![](https://www.thirdgen.org/messgboard/confused.gif)
If the chip is bone stock and the timing is at 0 then you have other problems. Maybe a huge vacuum leak or a bad ignition module in the distributor.
1992 Z28 5.7 TPI
ZZ4 longblock
Harland Sharp roller rockers
Accel base and SLP siamesed runners,
52MM SLP Throttle Body
Hooker Headers & Flowmaster catback
MSD6A ignition
aluminum driveshaft
World Class 5-speed
1992 Z28 5.7 TPI
ZZ4 longblock
MSD6A ignition
aluminum driveshaft
World Class 5-speed
Pac J
05-17-2020 10:44 AM
RedLeader289
05-28-2019 01:47 PM
bigjay89gta
10-15-2015 08:04 AM
Damon
09-26-2015 04:29 PM
