DIY/WB-02 display parts list
Car: 82 Z-28
Engine: 383 TPI
I built a diy wb-02 a few years back and have been using a voltmeter to display the data.
I'm now wanting to build a 40-LED display for my wb-02. Need a schematic and parts list.
I did a search, but most of the links are now dead.
diy-wb.com doesn't seem to be around anymore.
Thx!!
Thx!!
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Car: check
Engine: check
Transmission: check
Yes, however for it to be accurate one or the other needs to be re-calibrated. The LM-1 would need the output set up the same as the DIY-WB output. Or, the LED display calibration would need to be changed (IIRC just a couple of resistors).
RBob.
RBob.
RBob
Do you think you could send me a copy also. I started looking for mine after reading this and can't find where I stored it.
gary57210@yahoo.com
gary57210@yahoo.com
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hey rbob, could you send it to me also! thanks thirdgenlover@comcast.net
Car: check
Engine: check
Transmission: check
I have placed the DIY-WB LED Display files zip file on my web site. This will make it easier for everyone to access.
I knew it was was coming, just didn't know what it take to get me there.
Please remember, the design is by Bruce R., not me (He gets the credit for the design).
Here is the link, may need to right click and 'save':
http://www.dynamicefi.com/DIY-WB/wb-disp.zip
RBob.
RBob.
LT1Formula
20
11-14-2015 12:02 AM
