BURN1 Q's and other Q's
Car: 1990 Camaro RS
Engine: 305 TBI (LO3)
Axle/Gears: 3.08
First off BMmonteSS and Rbob, been checking every possible thread pertaining to 1228746 tuning, finally bought the tools to check it out because like everyone says, you cant tune the car without seeing it just by reading engine specs. I was wondering how to use the BURN1 to read stock 2732A chips to compare what i started to where I ended. I would check Moate's site but it's down for some odd reason. Since you guys both have expertise in these fields i was wondering as soon as i get to fixing WOT and pump shot in tunerpro I'm completely lost after reading countless threads on it. Thanks in advance for all the help. You guys are AWESOME!!
Car: 1983 G20 Chevy
Transmission: 4L60
You've got to remove the stock 2732A chip from its holder. Then insert it into the Burn1. Make sure that it is set for the 2732A chip (should say READ ONLY in the description). What is the 4 letter code on the Prom and the ECM? MANY Stock .BIN have already been read and are on several sites on the internet. I have about 100 on my Laptop alone. That way you don't have to sacrifice your stock chip.
Car: 1990 Camaro RS
Axle/Gears: 3.08
The chip was burnt by Motorvation so it's not the stock chip. I have no idea where the stock chip for the car is at actually. the code is AXKW the main thing i was wondering was where to put the 2732A chip because the burn1 has more than 24 pins
tazextreme3
16
08-30-2010 09:47 PM
