Tunercat tdf editor?
I'm ordering my burning equipment and have decided to use the tunercat software. I just need the tuner program and the correct definition file, right? Or do I need the tdf editor also?
'87 Formula WS6 - ZZ4 Crate TPI, SDPC ported heads, LT4 hot cam, 1.6RR, Accel runners, Accel lower, ported plenum, Edelbrock 58mm TB, Crane Fireball ignition, SLP cold air, SLP headers, !cat, Summit exhaust cutout, Walbro 255, Koni yellows, aftermarket panhard & LCA's.
Car: Death Mobile
Engine: 666 c.i.
I use TDF Editor ALL THE TIME. Though TunerCat is very progressive and constantly making changes, I do find it necessary to add certain constants and tables for my eprom burning which TunerCat has not yet defined.
Example, Tunercat does not have anything in the SD or MAF TDFs for modifying the "shift light" parameters. There just hasn't been enough "demand" for these parameters to be added by TunerCat. So if you want them, you need to do them yourself.
Also,you can modify the Temp Display from *C to *F if you prefer, though TunerCat is looking at offering those.
Car: 88 Corvette
Engine: 400, AFR heads, ZZ9, SuperRam, 730
Transmission: Slushbox
Glenn,
How do you figure out the locations and functions of the parameters that TunerCAT hasn't defined?
