TunerCat
TunerCat
I'm sure this is only the first of many stupid questions yet to come, but here it is.
In TunerCat, is there any way to change the Deg. C values to Deg. F values so I can more readily understand them?
[This message has been edited by ptc92rs (edited October 08, 2001).]
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
I don't know that you can with TC but just to get you in the ballpark, take the number in C, multiply it by two and add 20. This is nowhere near the formula for the conversion but it'll get you close quick. Of course I'm sure you could find a conversion somewhere on the internet and make a copy of it and have it as a cheat sheet. Another alternative is having a thermometer close by.
Download a conversion program. I did an internet search and found a great freeware program that does lots of conversions.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Engine: Many
Transmission: Quite a few
The conversion between celsius and Fahrenheit is pretty simple. Take the Celsius number, muliply by 9/5, then add 32(or, converting from F to C, subtract 32 from the number, then multiply by 5/9). You can easily set up excel to give you a chart that is a quick look-up.
<font face="Verdana, Arial" size="2">Originally posted by v8power:
I believe you can also use TDF editor to modify the values to display degrees C or F
</font>
</font>
408cid 1985 Corvette
http://www.mojosgarage.com
