Can anyone PLEASE help with AF tdf????
I've been doing fine with the 6E and 8D tdfs (tunercat) and I'm now going to help a friend just change the fans and a few other basics on his ZR1- but the constants are really different from the 6E and 8D. And no I'm not trying to charge $$ for anything! I only drink his beer! Anyway-has anyone done any tuning with the AF that I could ask questions from? Or know where I could find definitions for it????? Thanks for any help!
86 406
86 406
Car: Death Mobile
Engine: 666 c.i.
TunerCat does have a TDF for the AF. And DIY-EFI.ORG does have a bin for it also (based on my old foggy memory).
Most of they guys that work on ZR-1 proms do this for a living and probably won't be willing to share secrets. I can only reiterate the "basics" as I've never had any hands on experience with a ZR-1.
If you do decide to get the AF TDF from TunerCat, make sure you specify the year as there may be a second TDF (AFA) that may be for the later years.
1 Post
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by drive it:
</font>
</font>
Depending on the local gas, is about all you'll account for.
The ZR, and beginning with the LT stuff is really good.
It's the old if you want to feel faster add some timing/fuel, but the car won't be much faster. The exception again is what your local gas is like.
"N" ya need to be dead on reading plugs to double check yourself with that motor.
Car: Death Mobile
Engine: 666 c.i.
I have done some research and the ZR-1 does not use the AF.TDF (you are talking about the 5.7 DOHC engine aren't you)?
If it is the 5.7 DOHC engine, the 90-91s used the 1228331 ECM with the $8EA.TDF. The 92-95 5.7 DOHCs used the 16163993 ECM with the $D0.TDF.
Hope this helps.
Hope this helps.
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
Hope this helps.</font>
86 406
Grim Reaper
07-13-2002 05:01 PM
