Is something wrong with the winbin site???
Car: 1987 GTA
Transmission: 4L60e
I just went there and downloaded the "complete package" that was supposed to be over 2 megs. It's 137k and contains a game for a palm pilot. The zip says winbin and gozilla (downloading utility) says it has mirrors the same size at different sites. Does anyone have an alternate location to get Winbin? I've tried downloading it MULTIPLE times and had no luck. Thanks.
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by 3.1EyeCandy:
I just went there and downloaded the "complete package" that was supposed to be over 2 megs. It's 137k and contains a game for a palm pilot. The zip says winbin and gozilla (downloading utility) says it has mirrors the same size at different sites. Does anyone have an alternate location to get Winbin? I've tried downloading it MULTIPLE times and had no luck. Thanks.</font>
http://www.area51.org.il/~zaphodb/gmecm/
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
Thanks ZaphodB, sure are helpful. Must be hard getting parts in Sweden. Thanks for the download though. </font>
Downloaded the program, but I just can't get it to work.
I get the error messages ECU file error and error in ECU file, and then the whole program freezes.
I'm using the BIN and ECU files coming with the program, and yes I'm using the correct files (7165.ecu and 7165.bin)
What am I doing wrong?
<font face="Verdana, Arial" size="2">Originally posted by Norwaybird:
What am I doing wrong? </font>
http://www.area51.org.il/~zaphodb/gmecm/6Ev007.zip
http://www.area51.org.il/~zaphodb/gmecm/ARAP.bin
If you downloaded the one with a .ecu extension and used Explorer it gets corrupted, you should have gotten the .zip file....
Well I think there is something wrong with winbin itself (at least the version I've installed)
I tried yours files (ARAP.bin and 6Ev007.ecu), but the same thing happens. After the error messages the program freezes, and I just get question marks in the line indicating the version of winbin. (WinBin Version ?.??)
What's going on? I downloaded winbin from your site (zip-file).
Is there something you have to be aware of when installing WinBin?
Is there something you have to be aware of when installing WinBin?</font>
http://www.area51.org.il/~zaphodb/gmecm/WinBin14.zip
Which version did you try to use?
I found this to be caused by the selected type of decimal symbol. It must be a dot, not a comma. Open \My computer\control panel\regional settings\number\decimal symbol\ and select dot.
I also received the error message 'Run time error 8002': Invalid port number, or port type mismatch. Selecting different port addresses solved that problem in my case. \Control panel\ports\settings\advanced\IO port address\. More details https://www.thirdgen.org/techbb2/sho...hreadid=110700
