What .bin '89 V6 5spd '302ecm?
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I believe the $3A mask is the correct one for my application, but I can't find a .bin to match.
EDIT: Yes, I have searched my @ss off, there just isn't much info out there for us ('302) V6ers.
OK, I think I need the HNL5360 bin. I have found one called HNK5630 for the LB8. Anyone know the difference?
EDIT: Ah! The HNK5630 is for an auto trans. I'm slowly picking this stuff up.
I just placed my order for the Moates Burn1. Hopefully I can get the .bin. that way.
Car: Camaro 1988
Engine: 305, carb. 600cfm double pumper
Re: What .bin '89 V6 5spd '302ecm?
LB8 ftp://ftp.diy-efi.org/pub/gmecm/bin_lib/1227302/lb8/
How does this look. I cannot open at my employ.
LB6 ftp://ftp.diy-efi.org/pub/gmecm/bin_lib/1227302/lb6/
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
There isn't much out there because there isn't a complete hack of $3A publicly available. I've heard that someone was going to attempt it but probably gave up after realizing there were better ecm's out there. I put some stuff for $3A up on moates.net awhile ago. There's a little better xdf that has maf table scalars & a few other things added. You guys could always swap to a '165 ecm.
