winadl datalogging
Car: GM
Engine: GM
Transmission: GM
When using WinALDL, when you click the Datalogger tab it pulls up the logging box. Click start log, now you are logging. When you click stop log the data is saved in your "WinALDL" folder that holds the files to run WinALDL. Usually its in your programs folder. The data is saved as a .txt file and you can recongize it by the date and time stamp that is the files name (ex: 20060922_173739.txt)
Car: GM
Engine: GM
Transmission: GM
Car: GM
Engine: GM
Transmission: GM
check out the help section supplied with WINALDL.
data, datalogger, datalogging, file, files, gm, instructions, logging, save, saved, saving, stamp, time, winadl, winaldl
