winbin inj flow rate error?
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
Looking through some of the posts of people having trouble with winbin, and the most recent one of having trouble with the injector flow rate made me do some thinking. I came to the conclusion that the calculation used in the 730.ecu that comes with winbin is incorrect. The person wanted to set it for a 30 lb/hr inj which is 3.73 g/s or .268 sec/gram which should be a 0156 hex but winbin calculates it to 0268 hex. For AUJP it has a 01CC hex/2.79 g/s number (the 2.79 translates to 22 lb/hr). For a 305 bin it shows a 0202 hex/3.11 g/s number (which translates to a 24 lb/hr). If the calculation were correct it should show about a 2.4 g/s number for a 305 which would be about a 19 lb/hr. I see in a hac for the AHNT/$8D mask that the inj. flow rate is actually in (seconds/gram*256)*5 and then of course the hex equivalent. It appears the ecu in winbin has the calculation at inj grams/second*165 and then converted to hex. Now I hope this hasn't been covered before and I am not just wasting bandwidth here. Of course you can just do the conversion yourself and just enter the correct hex value at address $841C or at the editor window and ignore the g/s number but how can the ecu file be changed to have the correct calculation? It might save some aggravation to someone just wanting to make a simple change.
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I posted about this close to a year ago on the DIY EFI mailing list - you should be able to find the discussion in the archives. Sounds like the error may still exist in some of the ECU files for the $8D.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Tim
Should I just eneter the number and ignore the hex?
What does the hex do anyway if the number is what I need for my 30lb injectors but the hex is wrong? Or will it adjust itself when I change the number?
<font face="Verdana, Arial" size="2">Originally posted by MATEOZ28:
</font>
</font>
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
What does the hex do anyway if the number is what I need for my 30lb injectors but the hex is wrong? Or will it adjust itself when I change the number?</font>
http://ivilpenguin.area51.org.il/~za...m/730v3-md.ecu
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
ECU file?
I use 1227730. If that is the incorrect answer I'm sorry I'm really new to this and am REEEEEEEEEEEEEEALLY trying to learn </font>
ECU file?
Car: 78 Regal
Transmission: M20
Axle/Gears: 4.10
<font face="Verdana, Arial" size="2">Originally posted by ZaphodB:
Which ECU file do you use, I have seen at least two of them floating around, I belive the most correct one to be the one below, but since I use MAF and not SD myself I am not 100% sure. Maybe Glen knows?
</font>
</font>
Pac J
05-17-2020 10:44 AM
LT1Formula
10-08-2015 08:34 PM
