Weird TPI Prom ID Code
I am not sure if this is the right place to post this or what. If it isn't, just tell me where to post and then lock it, no problem.
Anyway, I put my diagnostic scanner on my 1985 IROC-Z TPI today, and checked the TPI PROM ID. I gave 7739. Looking on thirdgen/org's Tech place, the given PROM ID codes there do not match up. Can anyone shed some light as to why it'd be different, if I'm comparing the right values, and if I am, then maybe where the ID came from? Thanks
Car: Death Mobile
Engine: 666 c.i.
The actual PROM ID is part of the Part Number on the sticker on your ECM. The PROM ID displayed by a scan tool bears no relation to the "broadcast code".
FYI, my 7730 SD ECM has an AUJP1350 Memcal, but the PROM ID is 541 (stock).
Sanjay
08-12-2015 03:41 PM
