Winaldl question
Winaldl question
Does anybody know what the DRP ocurred flag is in winaldl? It seems to follow the rich flag. Idon't know what it means so I don't know if I should be watching it for any reason.
I'm not too sure. Here's what my datamaster help file says:
"This displays the current engine RPM as calculated from the Distributor Reference Pulse (DRP) rate. This allows displaying RPM Values well above the 8-bit datastream limit of 6375 RPM."
"Note that because DRP is measured at a slightly different point in time, and with greater precision than the ‘normal’ RPM calculation, the value is often 10-15 RPM different than the ‘normal’ RPM reading. This will be particularly evident during hard acceleration."
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
A google search on "Distributor Reference Pulse" should yield some info on what it is and what it is responsible for.
