WOT AFR vs RPM
1 Post
Car: RS
Axle/Gears: 9" for the ladies
WOT AFR vs RPM
Thats the title of one of my tables. I thought the AFR should be 14.7:1 at low RPM's and then drop to 12:1 at higher RPM's under WOT. My stock lo5 table says the below.
Am I to interpert it as 12.4:1 and so on or are these numbers a function of something else. If it is a 12.4:1 at 400RPMS shouldn't it be higher?
RPM | AFR
400 | 12.4
1200 | 11.1
2000 | 11.8
3200 | 10.6
4800 | 12.0
RPM | AFR
400 | 12.4
1200 | 11.1
2000 | 11.8
3200 | 10.6
4800 | 12.0
1 Post
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Aaron91RS:
RPM | AFR
400 | 12.4
1200 | 11.1
2000 | 11.8
3200 | 10.6
4800 | 12.0</font>
RPM | AFR
400 | 12.4
1200 | 11.1
2000 | 11.8
3200 | 10.6
4800 | 12.0</font>
You tune to what an engine tells you it wants. Never to what YOU think it wants.
Reading thru some of the past postings here will explain things in better detail.
355tpipickup
09-13-2015 11:35 PM
MikkoV
09-09-2015 04:25 PM
