XDF and ADLD
XDF and ALDL
I have read the stickys but still don´t get it
I´m trying to datalogg á 1993 LT1 with Tunerpro RT
What XDF and ALDL do i need to use to get it to work
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
This is a good place to start:
TunerPro and TunerPro RT - Professional Automobile Tuning Software
Look for "1993 LT1".
"$DA3 16159278 DA3.xdf LT1_1992-93.ads 93 LT1"
This is what i´m using DA3.xdf and LT1_92-93.ads
What could cause the zero output of values?
Transmission: T5WC
Hit Ctrl + F2 and look to make sure the bin size is set to match the actual bin size you're editing.
I´m not trying to edit only monitor/datalog to be able to edit the bin
The values don´t show up and when i record the error count is
When i open Tunerpro this comes
"mismatched XDF and ADS files" and i have DA3.XDF and LT1_92-92.ADS??
Transmission: T5WC
This means you're not connected to the datastream. What kind of vehicle is this? I do know that the DA3.ads file works on DA3 vehicles.
Transmission: T5WC
