ECU replacement from Chevrolet for my 86 IROC?
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Hey guys, I was reading another post on the tech engine forum, and saw the link to here: http://www.gmtips.com/3rd-degree/dox/tips/ecm/prom.htm
I own a 1986 IROC Camaro, and it has given me every engine code that i see listed on that page before, when none of the sensors were malfunctioning. How can i get a replacement ECU or whatever for my 1986 IROC Camaro, Vin F, 305 TPI?
I really doubt if i call a chevy dealership, if they will know what the hell im talking about. Is there a certain part number i need to know to get a replacement prom?
Thanks!!
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
Doesn't know enough about cars.
AIM: jesusathome
Thanks!!
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
AIM: jesusathome
1 Post
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Christos:
Thanks!!
</font>
Thanks!!
</font>
Well, i called up chevy, and got them to order and send me a "1228291" calibration pack.
The guy said it was for all 1986 vin "F" camaros. the ECU i have in there now throws me all kinds of stupid codes, so im going to replace it with this part to see if it solves some problems.
total cost was like $60.68 if anyone else out there has a 1986 IROC Camaro vin "F".
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
AIM: jesusathome
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
AIM: jesusathome
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: ECU replacement from Chevrolet for my 86 IROC?
sadly,none of these prom are avalible now from chevy.altho i also need to replace my prom for the very same reasons.should any members know of a alternative to a factory prom .please give me a shout
maf tpi chips are the easiest to find. any 86-89 5.0l maf chip will work in your 1227165 ecm. in 88 some have vats so you would need to bypass that and the 89 $6e and you can ditch that ninth injector. You can identify there year and programing bye the bcc broadcast code the letters on top of the eprom or on top of the memcal.
abwt is a 1987 camaro/firebird gm part 16068672 L98 5.7L GAS 8 CYL MFI, GW6 AXLE, REAR, 3.27 RATIO, MD8 AUTO 4 SPD THM 700 R4, NA5 FEDERAL REQUIREMENT. I have several tpi memcals and can reprogram if needed. Pm me if you think I might be able to help you.
could be any of these broadcast codes
ANY 3234 9501 700R4 N/A Cal/Fed F
AUM 3236 9521 700R4 N/A Cal/Fed F
BTZ 3240 9511 700R4 N/A Cal/Fed F
AWC 3243 9531 700R4 N/A Cal/Fed F
ANA 8964 9471 700R4 3.23 Cal/Fed/JP* F
ANB 8969 9481 700R4 3.27 Cal/Fed/JP* F
AND 8975 9491 700R4 3.27 Cal/Fed/JP* F
AWD 9004 9541 700R4 3.42 Cal/Fed F
AWF 9009 9551 700R4 3.42 Cal/Fed F
No I didn't I was just trying 2 make sure it has the right one in it it does have a new ECM in it were can I find that info at and thx for all your help
Hey are you still able to reprogram memcals for 1986 Camaro 305 tpi?
When I try to send u a private message is says I don't have authorization to the page.. sorry new here
My email is brianlvs@yahoo.com please feel free to email me
