How accurate is "Block Learn" numbers from diagnostic tools?
I've been recording some BL numbers on my auto xray. Just wondering if I can "rely" on these numbers to indicate where I need more/less fuel.
Are the WOT figures the only ones that are important?
Here is some info recorded at WOT.
3675 RPMS- BLN 128
4250 RPMS- BLN 128
4850 RPMS- BLN 128
This was in 85 degree weather. I have no runs to compare this to in cold weather. But would the colder weather effect this reading?
91 Formula 1LE 1 of 46
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 supercharger, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,custom chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
3675 RPMS- BLN 128
4250 RPMS- BLN 128
4850 RPMS- BLN 128
305 TPI 5speed
1LE/G92/WS6
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
You can't use your Block Learns at WOT since they're not used or adjusted by the computer, which is why they're at 128. You need to use the O2 sensor to get an idea of approximately how rich/lean you are, and use the trap speeds or a dyno to see if adding or subtracting fuel helps.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
theformula,
Re-Read the old posts on this board or do a general search on the internet that explains how GM EFI systems work. The ECM does not do WOT fuel adjustment based on the O2 ... only part throttle fuel adjustments based on the O2.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Tim
3.8TransAM
09-27-2015 08:37 PM
tcflint
09-27-2015 05:58 PM
