Special TDF for SD ecms....
Car: Death Mobile
Engine: 666 c.i.
I have defined the "Mag Bit switch" in a special TDF that I created called "XXX.TDF". It contains the Mag Switch (plus some other useful switches), the controls for "Low Octane" that I mention in another post, plus a few other interesting Constants to help control other things like your BLM and Decel.
I have forwarded this to TunerCat for incorporating into future releases of the 8D.TDF. TunerCat and I had a discussion on this a while back as to what would be the best way that this "experimetnal" tdf could be distributed to other 8D.TDF users. After some discussion, TunerCat agreed that if I forwarded these "experimental" TDFs to them, they would gladly forwarded to other 8D.TDF users simply by contacting them and requesting it. It is "experimental" and it is a "additional" tdf to the 8D, it does not replace it.
Also, I have created a version of the 8D that displays Farhenheith instead of Celsius in the temperature contstants called 8D4.tdf.
If you wish to get a copy of XXX.TDF and/of the 8D4.TDF, just e-mail TunerCat and explain that you heard that Glenn91L98GTA from www.thirdgen.org has submitted these two "experimental" TDFs and you would like a copy of them. Just remember they are "experimental" so any errors are not TunerCat's problem. But, I am sure the TunerCat would be interested if anyone notices any errors in them.
Please do not contact me directly for these TDFs as I agreed with TunerCat that they control the distribution. But for all registered 8D TDF users, these are available for FREE!
