palm pilot software
palm pilot software
Does anyone know if there is palm pilot software for scanning the ECM through the ALDL connector. I thought I read somewhere about some guys that were working the idea, but I cant remember where.
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Dang! That would be awesome if I could use my Palm to scan my car. I hope somebody figures out how to make it work.
Black 88 GTA L98
261 RWHP, 345 RWTQ
13.406 @ 103.72 MPH
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back, Stock PROM
E.T.F.A Member #11
Black 88 GTA L98
261 RWHP, 345 RWTQ
13.406 @ 103.72 MPH
E.T.F.A Member #11
1 Post
Car: 92 Z28
Engine: Boosted LSX
Check out this page. I dont know if this one will work for you or not but Its worth a shot.
EV1 Palm Interface
Peter's PalmPilot Interface
http://www.ohler.com/ev/EV1Dash.html
Chris
1992 25th Anniv Z28 W/383 Stroker
536 RWHP 569 FT LBS
(chassis dynoed at Ramsies Perf.)
www.go.to/TPI383
EV1 Palm Interface
Chris
536 RWHP 569 FT LBS
www.go.to/TPI383
Car: 82 Corvette
Engine: 350 CrossFire
I have an old Palm Pilot that I use for simple things (addresses, etc) but I found the pinouts and was going to attempt this myself; apparently it has a direct RS232 connection so you can get the cable for about $20, and make a serial port connection in your car for it. (AKM type cable or Peter G. cable.) Just have to find a suitable language/compiler set that would allow serial port interaction with the Pilot.
I'm trying to get mine setup just for plain 160 baud ('7747) since that's the ECM I'm probably going to use for all my cars.
Anybody know anything about programming the Palm Pilots?
Ken
Ken
