Question on tables that seem to override each other
Car: 87 IROC-Z
Engine: 383 HSR $8D
It seems that some different tables would override each other…how do they work together? I am working with a 165 ecm and tunercat...with the 6E def file
Let me explain...
Ie…WOT%Change to fuel/air ratio vs rpm tables and WOT %Change to fuel/air ratio vs Coolant temp tables should override each other. How do they work together? It would look to me like at operating temp…~200^F the computer would always add 18% fuel(per my bin) to the mixture at WOT…why not just set the original base value up that way? Also…you have that 18% being added…what happens at WOT as the rpm increases as your going down the track…does that 18% get added to by another 18% increase(all values are going by my apym code I am looking at)? I'm pretty sure the answer is no…but I'm just trying to figure out how some of these tables that would seem to override reach other would work together.
Thanks a million!!
GregF
87 IROC
Newbie in training.
Let me explain...
Thanks a million!!
GregF
87 IROC
Newbie in training.
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by gsf-87IROC:
Let me explain...
Thanks a million!!
GregF
87 IROC
Newbie in training.</font>
Let me explain...
Thanks a million!!
GregF
87 IROC
Think of it this way:
Just picking easy to see values
At 4dF CTS, it's AFR is 10:1, if you go to PE and it's 10% richer, then you'd be at 9:1 AFR.
One is %s and the other is AFRs.
HTH
Greg, I mainly just work with the RPM table. You can sorta fine tune with the RPM where as the Coolant table will be at all rpms at that particular temp.
David Tuschhoff
1991 RS Camaro M5
A SuperRammed, TPIS,
Ross, AFR, Scat, Crane,
CompCams induced 355!
My f-body page!
David Tuschhoff
1991 RS Camaro M5
My f-body page!
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
A little late in responding, but just adding to what Grumpy and David said. Those 2 percentages are added together, but only at whatever coolant temp and RPM you're at. Those tables are only used when you're in Power Enrichment, even though TunerCat calls it WOT (which isn't totally accurate since you can hit PE before going WOT).
I first tuned the RPM table first to get the O2's to vary much less while ramping up through the RPM's. Now I'm playing with the coolant table at the temps that my engine operates at when I'm drag-racing (a constant 170-175 degrees) to move the whole PE curve down. HTH...
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
