AXXD Knock test
AXXD Knock test
It appears that the knock test is disabled in AXXD by default, can someone confirm? It's supposed to be at $29C and I get FF (255) effectivly disabling the test initiation.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
That looks to be true.
There is also a Min MAP for the test at 29D = FF (disable)
the stock values in AUJP 29C = "B4" or 95*C, and 29D = "4B" or 75 Kpa setting to enable the test.
The amount of SA that is incrementally added for the test is at
29B ( = "$01" or 0.35 deg SA)
The maximum advance for the test is at 29E = $47 or 25* SA
raymondandretti
09-27-2015 06:43 PM
efiguy
09-27-2015 01:30 PM
