30lbs injectors
30lbs injectors
I have a normally aspirated 383 TPI engine with high flow heads, mid range cam, headers, custom prom, etc. It supposed to dyno near 450-500 hp at the flywheel. Would I have any problems with 30lbs injectors (that I already have) opposed to 24lbs injectors that would be just at thier limit at peak hp.
Supposedly I can reduce the injector pulse width to reduce the fuel to lean it out in case it would be too rich. My concern is lack of fuel with the 24's at peak hp.
What do you guys think? Anyone with a similar setup? I want to burn this prom but don't know whether I should get 24's or stick with my new set of 30's.
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Stick with the 30's. I am running them on my 350 and everything is great. Plus, they give you room to grow in the future.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Tim
thejimsterz28
09-15-2015 04:37 PM
