Connect LC-1 to 8746
Just finished my header installed and installed the wb-02 in the collector of the passenger side header. Is there a way to connect and log data through the aldl cable and winaldl? The LC-1 has a serial output for their software but I was curious if I could just connect to the ecm and get data that way.
LC-1 allows you to use the WB sensor to input into ECU in place of the NB sensor. i think that is a better sensor(faster?). that is in manual. some day i will give that a try but one step at a time for me. datalogging closed loop is done with winALDL or tunerproRT for most of us.
my "new" 8746 will have a port on it to connect serial cable to it rather than at the ALDL port. again just for closed loop. LC1 just logs A/F continuously on CL or OL as well as other data such as tps, map, rpm, etc.
