Where can I get a memcal?
I am about to get into prom burning, but I want a spare memcal to make the modifications
to (solder in a zif, etc).
Anybody here got a spare they want to sell, or know of a place to get one or two?
Other than the proms, are all memcals the same, or are they different for different years?
89 Firebird Formula
WS6 package,ZZ4 Crate engine
SLP 58MM TB, Edelbrock TES Headers
Random Tech 3" cat, SLP 3" stainless exhaust
9 bolt rear, Hotchiss swing arms, Lakewood panhard rod
Corvette 2/4 servo, kevlar band, full poly rear.
Centerline 16x8 rims, B.F Goodrich drag radials
89 Firebird Formula
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Spare MemCals are available from the GM dealer. Give them a call. They cost about $45. Yes, different years have some things that you want to watch out for. Don't use a '90-'92 in place of a '86-'89. That's the biggest rule.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Program your own PROMs. Read my article on how to do it!
Tim
Car: Death Mobile
Engine: 666 c.i.
It is best that you get the ecm and remove the memcal. Even for certain years, there can be a variety of memcals available for the same car. With the proper broadcast code the dealer will get the most up todate from GM available for your car.
For example, my car originally came with an "AUJP 1350". When I purchased a second memcal, "AUJP 1615" was the latest revision.
Initially, I would just erase/burn onto the spare memcal until it's being erased/burned one time too many.
88SS6SPEED
11-11-2015 07:05 AM
