VATS removal on tpi install in truck
I just put a tpi system in my 1989 C1500, I did not get a VATS module with my 7730 ecm and harness. Is the Vats system active through the ecm or the vats module. What do I have to do to disarm VATS if I only have the blue vats wire coming from the ecm?
I'm having the same problem. I bought an ECM and PROM from a 1986 'vette and found a day later that the VATS was installed in the 'vette starting that year. I don't have a PROM burner or a VATS unit, and the only effect the VATS seems to be having is that the injectors shut off after the engine runs for about 2 seconds. I found a link for an oscillator for the VATS circuit, but it is for a Passkey II system. I'm not sure if the older VATS can be handled similarly. For now, I'm screwed.
Well I'm sure one of us with access to a burner wouldn't mind burning a chip for you with the VATS removed. If you need this done... I would do it for you. Let me know.
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
92 Z28 L98 350
Sanjay
08-12-2015 03:41 PM
