Burn Chip from 7747 for tpi setup
I converted my wiring harness from tbi to tpi. Had the 7747 ecm and still want to use it and my original harness w/ mods. Can I burn the 7747 chip to operate the tpi, still a batch fuel delivery setup, just different pulse widths if I'm not mistaken. If so, can someone lend some help, have a 7730 ecm w/ ads superchip installed to trade possibly.
Nick
Nick
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Do you have a prom burner so I can just send a .bin file??? Do you have a scanner or Diacom or ??? I enjoy bartering so noone spends much money.
-Carl
p.s. I personally don't think you can ever get a 747 to act properly with a TPI type setup without redoing a bunch of run-time code. I recently spent quite a few days working on a AZ speed & marine manifolded 502 with a 747 and got it to work "pretty" well, (the idle and part throttle surge is a real pain) this controller was never designed to do this.
-Carl
-Carl
-Carl
Sanjay
08-12-2015 03:41 PM
