Calculating duty cycle based on RPM and PW
Car: Death Mobile
Engine: 666 c.i.
I am looking for a formula that will calculate the % duty cycle based on the RPM and Pulse Width of the injector.
I think I have derived a formula, and I want to run it by you guys to "pick it apart".
The formula I have came up with is PW * RPM /60,000. This will give you a decimal with .5 = 50% and 1.0 = 100%.
How I came up with the constant was to figure out total Pulse width in a minute @ a given RPM. I worked on the assumption that the PW is based on the duration of firing for each revolution. Also there is 1,000 ms every second, so there is 60,000 ms in a minute.
At 6,000 rpm, and engine requires 10 ms to complete a revolution (60000/6000. Thus if my max PW @ 6,000 rpm is 10 ms.
I have done various "cross calculations" and I have related it to the standard (HP*.5BSFC)/(#Inj*%DutyCycle).
Using the above formula, and the following is the max PW @ 100% Duty Cycle for various RPMS.
RPM.....PW ms
1,000....60 ms
2,000....30 ms
3,000....20 ms
4,000....15 ms
5,000....12 ms
6,000....10 ms
I should point out, that this is if we measure PW being measured over a single revolution at a given RPM. If we measure PW every power cycle, then the constant would be 120000 (60000 x 2) and all the values about would have to be doubled.
[This message has been edited by Glenn91L98GTA (edited December 29, 2000).]
RPM.....PW ms
1,000....60 ms
2,000....30 ms
3,000....20 ms
4,000....15 ms
5,000....12 ms
6,000....10 ms
1 Post
Car: An Ol Buick
Engine: Vsick
RPM.....PW ms
1,000....60 ms
2,000....30 ms
3,000....20 ms
4,000....15 ms
5,000....12 ms
6,000....10 ms
RPM.....PW ms
1,000....60 ms
2,000....30 ms
3,000....20 ms
4,000....15 ms
5,000....12 ms
6,000....10 ms
forra single batch fire.
SEFI just double the numbers
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Grim Reaper,
Your math is correct. With that you can see why the SEFI can run a larger injector and not complain about idle BPW problems. One thing to note is that code like the $8D does not actually report the BPW via the ALDL that is sent to the injector. It also brings attention to what a BPW actually is........including the turn off/on time or not, voltage correction, etc.
EDIT: Wow, old post. Info above is for batch fire port injection.
Car: 1983 G20 Chevy
Transmission: 4L60
Calculate it based on RPM
Let me take 6,000 rpm, it is a nice round number
With TBI you have 4 injector firings per crankshaft rotation. That is 2 per injector driver.
At 6,000 rpm the engine is turning 100 times per second
That means that you have 10 msecs per rotation.
The injector has 5 msec's per firing @ 100 % DC.
1 millisecond is equal to 1/1000th of 1 second.
mrestrictrplate
09-21-2015 11:24 AM
MikkoV
09-09-2015 04:25 PM
60, based, calculate, calculating, calculation, calculations, cycle, duty, formula, gen, generation, pw, relating, relation, rpm, rpms
