Does the "rev limiter" setting in the bin actually work ?
Since I have a messed up transmission and there's no telling what RPM the engine might reach by mistake, I though it would be a good idea to limit the engine to 5000 rpm using the rpm limit setting (fuel cutoff) in TunerCat right below where you set the top speed mph limit. Well I took it to 5500 rpm and no fuel was cut off! I guess it doesnt work on my car, or has it not been implemented or something or what ? LoL
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.org/Members/Chev...dmondIndre.htm
92 Z28 L98 350
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Sure does! I accidentally bumped into mine the other week when I was passing another car and forgot I had left my shifter in 2nd gear. I set mine at 5200 rpm since I shift at the track at 5000 rpm, and with over 127k miles on the engine (everything inside is original), I don't want to chance ruining it if somethere were to happen to the tranny, rear end, or whatever. Might want to check your settings in TunerCat again. Notice "settings" is plural. The higher rpm is to activate the rev limiter (cut off fuel), while the lower rpm is to stop the rev limiter (bring back fuel)...
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Well I had it cut off fuel at 5000 and bring it back at 4800 rpm. Soooo... I doubt I messed up in THAT area. Oh well, maybe my tach is off or something. LOL But I'm not gonna risk taking to 6000 again. I took it to 6500 and pulled a stud. LOL
92 Z28 L98 350
92 Z28 L98 350
Car: An Ol Buick
Engine: Vsick
ie 3,000 rpm that way you can make sure that its working.
you will know the very first time why--the prom method is crude and very distinct.not at all like my msd soft touch that acts like the car is missing.it also creates a very lean condition everytime it takes place
1990 Trans Am,350 TPI(L98),WS6suspension ,bridgestone RE71's /245/45/zr16
paxton supercharger, alston sfc's,msd 6AL-BTM,
8.5 superconductor wires SLP 1-3/4 headers,duel cats,3"slp exaust, lakewood LCA's,T.B.Bypass
160 degree stat,alum driveshaft,fiberglass wing, secret mods
"if you cant win fair CHEAT"
So the ECM will drop the fuel pump entirely, when you reach the rev limit? Like the previous post said, wouldn't that lean out the mixture while the residual fuel in the rails bleeds off? Hopefully the ECM is smart enough to at least stop firing the injectors while the pump is off!
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
It doesnt turn off the fuel pump, it just doesnt fire the injectors.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
hectre13
08-26-2015 08:17 AM
