blades bin repository
Old 11-20-2000, 08:33 PM
blowen90ta's Avatar
why cant i find it anymore?i finally have everything to burn chips and need some bins to compare where others have started.i'm especally interisted in bins from boosted apps.anyone kmow where to look?been reading everything i can find and see it will take many attempts to get it right but i've got all winter to get a few ready.i.ve also herd that there are timing differences in aluminum headed vette's of the same year is this true?if so maybe i should start with a vettes timing curve and go from there?that way i'll be taking advantage if the new afr heads better!
any advice is helpful
thanks pete
1990 Trans Am,350 TPI(L98),WS6suspension ,bridgestone RE71's /245/45/zr16
paxton supercharger, alston sfc's,msd 6AL-BTM,
8.5 superconductor wires SLP 1-3/4 headers,duel cats,3"slp exaust, lakewood LCA's,T.B.Bypass
160 degree stat,alum driveshaft,fiberglass wing, secret mods
"if you cant win fair CHEAT"
Old 11-20-2000, 09:45 PM
Blade's Avatar
Try this....
http://www.truspeed.org/bins.html
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.org/Members/Chev...dmondIndre.htm
Old 11-21-2000, 09:06 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
thanks pete
The curves from iron to al heads are totally different. and with boost even different still
You can run alot more timing in cruise safely with the AL heads, but need alot less at WOT, and less yet in boost.
Might look at the www.syty.org area and look at promgrammer. Some have used the 749 in boosted v-8 applications.
Small combustion chambers will be the successs to that engine
Old 11-21-2000, 09:35 PM
blowen90ta's Avatar
thanks grumpy,i find that info great-but i am wondering if the ecm that i have now could be calabrated to reconize boost?i have seen some info on this but no hard fact of anyone saying they have done this.hate to change out the ecm till i get what i have running great (guess i'm a sucker for small details )still looking for a stock corvette bin to compare to my current bins that i have for the t/a--just playing right now because of no way to actually test anything till spring,hopefully by then i'll have a new cam and 30 lb injecters installed
Old 11-22-2000, 05:02 AM
F22Raptor's Avatar
GOOD GRIEF! This bin-chip talk is to complicated for me at this moment. I have never paid attention to any of this matters and don't have a clue what ya'll talkin' 'bout. So anyway, does any of you sell a custom chip for something like 30-40 bucks?
'88 GTA 350
Headers, catback, free mods, Xtreme energy cam, and intake pieces
13.51@104.27, but can run better as it is.
I just put a new 2100-2300 RPM TQ Converter. I hope a 13.20 or better
RAPTOR, the baddest bird on the planet
AIM HIGH!
gixxer92
04-12-2022 12:09 AM
Elephantismo
02-13-2019 12:51 AM
antman89iroc
36
01-31-2016 08:42 AM
Rocket-Doc
11-14-2015 02:08 PM
Quzyle
10-15-2015 03:35 PM
Quick Reply: blades bin repository
