Programming for performance vs economy
1 Post
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
How would one go about doing this? I have a DFI setup that I think I've programmed well, but my mileage still sucks. Would one program lean for cruise and idle then rich for WOT? Just thought it'd be an interesting topic.
Bob
Bob '89 Formula CC350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
Bob
My car's homepage
Yes. 14.7 - 15.0 for cruise ( could go higher buy WHY risk engine damage?) and richer for moderate/high load situations. OEM ecu's do this by running in closed-loop for most operation but going to open-loop at richer stated for moderate/heavy loads...
1 Post
Car: An Ol Buick
Engine: Vsick
[B]Yes. 14.7 - 15.0 for cruise ( could go higher buy WHY risk engine damage?) and richer for moderate/high load situations. OEM ecu's do this by running in closed-loop for most operation but going to open-loop at richer stated for moderate/heavy loads...
Properly tuned you can go leaner then 14.7. The 14.7 is an average, meaning about 50% the oem range is leaner then that.
Properly tuned you will have a economy race chip. Only exception is if you change fuels for racing. I can run at 15.3 just fine thank you. Will be looking to lean that down more in the futrue
Damon
09-26-2015 04:29 PM
