Need def and ads for 16144288 ecm
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I need to help a friend tune his V6 truck. The ecm/harness/engine is from a 91 S10. I use Tunerpro, but I have Tunercat also. Any info would be helpful.
Thanks,
Ron
Thanks,
Ron
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
The XDF I have no info on, from the "ALDL Stuff" index it looks like the ADS could be made from "A58" 4.3L TBI
(LB4) (VIN=Z) 90 91 S/T TRUCKS w/autoc TRANS
Would be "A104" if its a manual trans.
Could be one of the others listed, you'll need to decide based on what you have.
Engine: LB9
Axle/Gears: 3.55
Thanks for the info. I found that tunercat sells a def for it. I'll just go that route. I can't seem to find anyone that has tunerpro for it.
2012sergen11
10-13-2015 07:38 PM
