making aldl interface...
Old 10-27-2000 | 06:01 PM
DMan's Avatar
I'm using Carsten Meyer's schematic @ http://pweb.de.uu.net/pr-meyer.h/aldl.htm . I got all the stuff together, but forgot to ask the guy at the store which way the capacitors go. The end with the short pin has a stripe, but which is it represented by in the diagram?
Thanks,
Dennis K
88 Formula 350
Old 10-29-2000 | 07:13 AM
c3go_92RS's Avatar
On the MAX232 + goes to pins 1, 2, 4, 15, 16 and the + side before the 7805, check your work because the MAX232 is unforgiving, will blow in a heartbeat. Hope this helps
Old 10-29-2000 | 09:33 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
[This message has been edited by Craig Moates (edited October 29, 2000).]
Old 10-29-2000 | 12:08 PM
DMan's Avatar
Dman,
Take your dumb *** over to one of the other diy sites, they have similar schematics with polarity clearly marked.
Later,
Dennis K
This was an attempt at humor. Had it been an actual example of humor, it would have been followed by incessant laughter and extended snickering. Repeat, this was only an attempt.
88 Formula 350
[This message has been edited by DMan (edited October 29, 2000).]
chazman
08-28-2018 03:25 PM
mike_c
08-27-2015 04:32 PM
86White_T/A305
08-17-2015 12:16 AM
z28addict8490
08-07-2015 08:48 PM
Quick Reply: making aldl interface...
