autoprom emulation verify fails
Car: 1989 Firebird GTA
I have a 89 gta 6E mask.I can read and burn chips,data log but not emulate. When I upload bin it is succesful but when i verify it fails.The chip works in the car if I burn one.Even if I disable the checksum it fails.I know it use to work about two months ago but I can't seem to figure it out now.
preferemces in default xdf are I.D.offset 0X09 mask 0x6E
xdf path c:\program files\tumerpro RT\bin definitions\6E.xdf
I've tried unistalling and reinstalling tunerpro rt and different versions of it.Different usb cables.No luck!What am I doin wrong?Any help would be appreciated.
thanks
thanks
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I know I need to have the key on to verify.
Preferences to AutoProm, blah, blah
Switch twards the center of the AP
Latest version of TP
Firmware up to date (should be but its nice to check anyway)
Also check the emu cable that you don't have any crossed or piched wires in there.
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Try uploading and verifying with the device connected only to the USB port. Upload several times, and verify several times. If you still seem to have a problem, you can of course return it for repair/replacement/refund.
Thanks for the reply Criag.I found the problem about 3 p.m. I had apparently drop it and knocked the chip loose on the inside of the device,took the cover off pushed the chip back in and now works again.It only took me two weeks to figure it out!
Kevin
Kevin
Car: 87 T/A
Excellent, glad to hear it!
One more thing for anyone else having a program/verify problem with the AutoProm: This can occur if a chip is in the ZIF socket at the top of the APU1. If you're trying to emulate, make sure you don't have a chip in the ZIF socket on top.
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Originally Posted by survival
I have Tunerpro 4.13, firmware 2.8, switch towards usb ,cable looks good.
thanks gor the reply.
You should be good to go with what you've got, but I did want to point out that your firmware is on the older side.
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
