Can't get TTS Datamaster to Link...Driver issue?
1 Post
Car: 89 IROC-Z
Engine: 383
Ok so I need to do some datalogging with TTS Datamaster and first I tried my old printer port cable from Diacom and realized that won't work. I borrowed an Autoprom from one of my buddies with the USB cable and I downloaded the drivers from here: http://www.moates.net/documentation....entation_id=15 I installed the drivers and configured the port as stated and couldn't get a link for TTS or with Diacom. I restarted and tried changing a few other things with no luck. When I went to Device Manager it only listed Port 3 USB but didn't have Moates name listed like the directions said. I decided to try and start over so I went into the unzipped moates directory and used the unzip tool. Now it won't let me reinstall. I went back to the device manager andit has no port 3 listed and the USB Serial Converter says it's missing a driver. Do I need to uninstall this as well and then reinstall everything? I'm not super savvy with computers so I didn't know if that was a good idea or not. Any help would be greatly appreciated. I need to datalog ASAP so I can finish getting this car ready for Power Tour.
Thanks in advance.
Thanks in advance.
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
So far i've only gotten Datamaster to work with my old serial type cable. I've also tried to get it to work with my autoprom without any success.
Car: 91 RS
Paul back a year ago when I first bought a laptop and started as a newbe to logging I ran Datamaster with no problems on a 1993 pickup (E6 I think). I used the Moates ALDU1 adapter. It I think is the same as is in the Autoprom for the datalogging. I also used it with other loggers with zero problems. Worked first time every time. I would recheck the driver settings.
HTH
HTH
1 Post
Car: 89 IROC-Z
Engine: 383
I have tried to uninstall and reinstall the drivers 3 times now with no success. At this latest install I cannot choose COM 3 as a port in TTS's ALDL Check program. What am I doing wrong here?
Car: 1991 Firebird
Engine: Chevy ZZ450
Transmission: 700 R4
Have you checked the settings in the BIOS. See if the serial port and the USB ports are "Enabled". Just a shot hope it works.
Jim
Jim
1 Post
Car: 89 IROC-Z
Engine: 383
Jim
Jim
1 Post
Car: 89 IROC-Z
Engine: 383
Ok I think I'm set now....it's passing the ALDL test now....got too late to try actual datalogging though. My buddy and I disabled the COM1 port as well as the internal modem and infrared devices. Worked like a charm after that.
1 Post
Car: 89 IROC-Z
Engine: 383
Originally Posted by Steve40th
I am having the same kind of problems. Why did you disable the #1 Com port. Was it highlighted as a port to use when you tried recording?
A friend suggested it...something about it interfering with the communication. I just did it on a suggestion and it worked out for me. Can't hurt to try.
