WinALDL Qustion??
Old 05-03-2006 | 09:41 PM
Stevemel98's Avatar
Car: 91 FireBird
Engine: 350 TBI
WinALDL Question??
I have been searching through the site and have enjoyed all the great info concerning tuning. I have a 91 firebird with the 8746 ECM. I am using WinALDL to log data. Were does the injector pulse width show up in the logged data? I have looked and can not find it. I am sure am doing something wrong,, I just can't find what it is. I think my injector are going static but I am not sure since I can't find the data in the log. Thanks for any help.
Old 05-06-2006 | 02:08 AM
MadDogginYa's Avatar
Car: 88 Burb
Engine: 74' 350 I built
Transmission: auto 4x4
Winaldl!!
I don't believe you will find injector PW in winaldl. It is just a progam to record data from your ecm so you can compare and make changes in whatever other software you are using to modify you Bin. I hope this helps a little bit. Winaldl logs error codes, BLM's , raw data, sensor info, knock , o2 sensor. BPW is a combination of alot or I should say a very long math equation done by the ECM. If you stay on the stickys you will find it. Alot of great info here on TGO! GL!
Old 05-06-2006 | 09:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The PW and SA can be patched inot the ALDL data stream. Over on the TBI board, in the stickies is a thread about tuning. I believe that information is in that thread. If not check the stickes above for the tuning guide book in the 8063/8746/7747 section.
RBob.
Old 05-07-2006 | 02:17 PM
Car: 88 Burb
Thanks for the info on that RBob
I didn't realize those things could be seen in Winaldl. I will follow up the suggested reading for sure. Thanks RBob
Old 05-12-2006 | 06:16 AM
Stevemel98's Avatar
Car: 91 FireBird
Engine: 350 TBI
Thanks for all the great info. This what i was looking for. hopefully I can get the car tuned out now. Thanks again
Steve
kyrenegade
09-08-2002 03:05 PM
JoBy
04-27-2002 07:55 PM
JoBy
02-09-2002 06:08 PM
zupmanZ28
Carburetors
03-26-2001 07:46 PM
Quick Reply: WinALDL Qustion??
