Tuning with the EBL
#3601
Re: Tuning with the EBL
Originally Posted by whatif3387
If anyone could help offer me any advice on tuning cold idle that would be great. After initial start the idle flucuates from around 550-1100 rpms while the afr bounces from 13-19 afr. Once temps reach 115f/46c the idle smooths out alot.I'd also like to add that once warmed up it idles super smooth at 700rpm 30map with IAC steps at 5 but my "IAC - Idle Speed Park" is commanding 575-600 rpms what could cause it to be off 100 rpms?
#3602
1msec = 1000usec. msec = millisecond and usec = microsecond. We typically refer to pulse width in terms of milliseconds or msec (or ms). The injector offset is in terms of usec because it's a small value, but we could easily say 400usec = 0.400msec. Same thing.
You could try cutting the offset in half (table on the right). You'll need to retune your VE and it may not even idle.
#3603
There is another area in the XDF to control your steps during cold startup, although my location may be labeled differently (IAC - Powerup Init Steps), and it targets the step value based on the corresponding coolant temperature, yours may need some attention below 115-degrees, those values in your bin may be too high and letting too much air in, especially with only needing 5 steps to idle correctly once fully warmed up. As for the 100-RPM difference, is your throttle's fast idle screw fully closed?
#3604
I've been staring at that parameter for awhile now and have been hesitant to mess with it since there's so many IAC settings but I will try messing with that when I get a chance. Also I'm pretty sure the screw still has room to go both ways. From what I understood I adjust the screw until I see the steps I want at idle in the WUD and then after a restart the IAC will reset and will correct to minimum idle which is why I'm confused as to why it's not whats being commanded.
#3605
Keep the fast idle screw closed, the IAC wants full control. If your running a cam as big as mine you'll want to help the IAC maintain the idle by cracking the throttle blade open until your happy with the steps. Back off your fast ide screw, close the blade, and watch your steps increase with just the IAC controlling your idle, and your RPM will lower to the commanded value. A 5 count is very low, almost closed. If I had the XDF I would look at your bin, as it sounds like some of the other settings are playing tug of war with the commanded steps and commanded afr...
#3606
I was under the impression that I needed the steps to be 5-10 at warm idle since I was running TBI? Or is this something that really depends on what the engine wants because I'm still running the stock cam in a month or 2 I'm gonna swap it out for something else and I'm sure everything will change and I'll be tackling all of this over again lol.
#3607
Yes, but the difference between those 5 & 10 steps is your extra 100-RPM at idle. I didn't mean to imply that the steps will be able to go up drastically once you close the throttle blade, the steps will just go up enough to maintain the commanded without any help from the throttle. If you command 5 steps at warm idle, but introduce more air during warm idle by cracking the throttle blade open, you essentially created an even larger vacuum leak that your IAC cannot correct for. Give it full control and see what happens...
#3608
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
So what we do is this: knowing that an injector flows X amount of fuel at Y pressure (let's assume static pressure for now), resulting in a mass flow in pounds per hour, we can assume that holding the injectors open for say a tenth of an hour will result in a tenth of the fuel. The same thing happens when you hold it open for fractions of a second.
Here's your pulse width, or the easier way to refer to it - the short window of time where the injector is open.. the width of the window where the ECM sends a "pulse" to the injector to open.
Remember that this happens every (other!?) revolution of the engine, and hence that an engine rotating at 6000 rev per min (= 100 rev per sec) will only leave 1/100 seconds (10ms) per revolution for this window at max! This is also where the Duty Cycle comes in, expressing the ratio of time that the injector is open (PW) to the maximum possible opening time due to the engine speed. 50% means your injectors are only open during half of this window.
Furthermore, the injector offsets which we've been looking at, compensate for the time needed for the injector to open and close, because it is a mechanical device. It will take some time for the electromagnetic actuator to energize and lift the pintle of the seat (injector opening process). If you go back to kevm's post, he stated that e.g. an extra 400usec (400 microseconds, 0.4 millisec or 0.0004 seconds) are needed for this. When you have a PW (pulse width, time of injector opened) of 1.2 msec (1200usec), this is quite a big influence (33% difference). At 6 msec PW, 400usec are not quite as critical (6.7%).
By the way the opening injector pintle is also acting against the prevailing fuel pressure, that's why the injector offsets need changing by quite some amount when you raise fuel pressure.
HTH and that i got it right lol
#3609
Thank you for that very informative post I'm seeing things a little more clearly now. So based on what you said I don't know if you looked at my screen shots in my previous posts but I originally doubled my injector correction offsets when I setup my first bin a year ago. Others have mentioned that maybe to much, would this be because even though I'm running 80lb injectors I only actually increased my fuel pressure 2 psi over stock. I'm assuming PW is more relative to fuel pressure then it is actual injector size. Now after knowing all of this is there more accurate way to determine what my tables need to be based off of a calculation I could do or is it more of a trial and error thing?
#3610
I posted thread some time back where several of us commented. Also tips are given as to what to look for that would indicate when offsets need to be changed. I run my 75 lbs injs at 21 lbs fuel pressure. I believe my offsets are about right. I could post them for review.
#3611
1 Post
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Port fuel injectors I believe are published. I recetly bought them (24lbs) and they came with the needed offsets. I think there were like 6-8 differing values that a tuner might use. TB injectors I dont believe were published. I think RBob once calcuated voltage based offsets and are in a thread here some where.
91' bird 305 TBI T-5, trick flow 175 cc heads, 4.10 gears, lots of suspension upgrades......... 24mpg @ 2300rpm hwy 65mph ........ 8.63@ 85mph 1/8th on street tires... 8.000's soon
#3613
Engine: LS1 / L03
i'll give it a try to dig it up.. also yeah most port fuel injectors have data from the manufacturer available, with factors to scale the offsets with fuel pressure and voltage and all that. btw, what are 75# injectors?
@whatif, glad it helped let me recommend reading (at least) these two links to you from rbob's site, i find they help quite some to get your head wrapped around the basics and then some
http://dynamicefi.com/Tune_Intro.php
http://dynamicefi.com/Tune_Intro2.php
on the offsets, yeah as you said basically you're not that far off from stock pressure (although service range is 9-13). if you talked setting the offsets over with rbob, i'd be pretty sure they are correct, but might wanna shoot him email again with your VE table and the offsets and doublecheck.. or he might chime in here soon anyways
edit: did some digging with the search function but couldn't come up with something definite.. not sure if this link to the search results is working, but here's also the keywords i used:
Search: Keyword(s): tbi, injector, offset, 75 ; Posts Made By: Ronny
hey i just looked at the #80 @22psi injector offsets in provided calibration 3001... they are lower than the ones you posted, whatif! so i'd guess it's safe to say the ones you are running are too high! at 14.4V, 3001.bin shows 778usec, yours 793usec.
#3614
#3615
GM 17112560 . I believe it is commonly called a 80 lb injector but I think RBob flowed it at 75 at 12 lbs FP. He posted that many years back i recall. I went with it.
Not sure on this but if the offsets/compensation are off the integrator seems to be moving excessivly.
Ownor do you recall what may be the minimum usec the injector can pulse assuming my injector at 21 lbs FP? I am seeing 1.6 steady at idle and in DE I can't get it under 13.5/1 (20MAP) even though my VE has very small values in 20 MAP cells. I idle OL and see 14.3-15.0 on WB at 750 rpms 45 MAP.
#3616
Engine: LS1 / L03
Yeah, sure didnt mean it in an offensive way when posting those links, I know these things take time to sink in just as you say
Maybe starting out from a 5.7 bin is a good idea, although I'm not sure how much more offset the #80 injectors would need even at stock pressure compared to smaller 350 injectors.. This post suggests there isn't much difference between SBC and BBC injectors, so you might get away just fine by multiplying in accordance with the mild increase in fuel pressure for your setup.
Ronny: damnit, i just got a pair of these.. So they are 75 huh? Interesting..
I don't have a definite answer for your question, sorry, but would be interesting for me as well. Hmm, seeing 1.6 msec in WUD? That includes the offsets.. So guessing real PW should be somewhere like 800 usec with that injector and FP, idle is stable at that PW? Not sure but you _could_ go async for DE maybe..?
#3617
No offense taken that really is the best way only way to understand this stuff for a DIY is constant reading and just playing with changes to learn what works through experience. I knew when I was getting into this it would be a huge challenge but from all the knowledge I've gained its been well worth the trouble. And now after discussing all of this stuff involving the PW and injector offsets I can completely understand why my VE tables look so strange to people. I'll be reporting back with my results at some point this weekend after I get a good amount of learns done. I'm planning on increasing the offsets slightly more then stock and replacing my VE tables with the stock ones and starting over.
#3618
#3620
Guys, stock LB9 bin has IAC - Gain set to 12.55% in both Park and Gear. IAC reaction is too slow in my case with my mods, so as a general rule we normally bump it up in 25% increments until it becomes unstable, then back it off a few until stable again. Now, in terms of Idle - Gain Breakpoints, the stock LB9 bin embellishes 50.00 RPM (High) and 37.50 RPM (Low), what would you recommend the offset/relation be with the change made to the IAC - Gain, say if my IAC - Gain values are now reading closer to 30%, and do the IAC - Gain Breakpoints need to be changed at all. Please elaborate on why you think they do, or why you think they don't. You will be graded...
Edit: 30% of 12.55, meaning 3.765% more totaling 16.32% in Park and Gear...
#3621
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
The injector offset compensations wash out the *mechanical* delays involved in the inertia of the parts. ( and the current bucking characteristic of the inductance of the electromagnetic armature ) The real time it takes to open the pintel from some percentage of open to some other percentage of open, and vice versa on closing. Note that it's not from fully closed to fully open !
My best advice on those, would be to find a stock bin from anything that used the injectors you have, copy those, and leave them alone !
When I went from 12PSI fuel pressure to 23PSI I didn't touch them. Why ? Because 11PSI change is not enough to affect it in any meaningful way.
Based on the area differential, and therefore the pintel pressure differential vs. magnetic force, I'd be a little surprised if 50PSI change made much difference, if any.
It's real easy to "correct" A when A was fine, but B needed a tweek. If one does correct A, then both A and B are wrong, and things will get real complicated real fast.
Take it for what it's worth.
#3622
Engine: LS1 / L03
Cflick, i don't think i have any data to back this up, but when I went from stock pressure with an old TBI pump to somewhere like 15-18 psi TPI pump fed on the stock L03 injectors, before tweaking the injector offsets i would run into the bathtub phenomenom. also, FWIW.. but from what most of us are experiencing and doing, i think there's indeed some influence on injector offsets from pressure change as well.
#3623
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
#3624
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
Having a problem ... I've noticed since I went closed loop my AFR always stay around 14-15 even if its in pe mode at 30% throttle or 100% wtf ? Thanks
#3626
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
In the datalogs its showing pe active
#3627
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
I switched it back to closed loop to cwhat happens
#3628
Ownor,
I would agree w Cflick. I wouldn't play w IB to compensate for increased FP.
IB is a primary parameter which helps form the basis for fueling calcs. It needs to be accurate. Increasing the FP affects the calc'd BPC. That needs to be altered to accurately reflect the current situation.
#3629
Car: check
Engine: check
Transmission: check
RBob.
#3630
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
I prefer closer to 12.0:1 on E10, but he may be referring to reported, in which case maybe there's an issue with the sensor/controller.
#3632
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
#3633
Car: check
Engine: check
Transmission: check
RBob.
#3634
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
here is a compressed zipped datalog csv file go down to about 7:20 runtime
thanks for any help I wanna go to the track tonight n need HELP I need some good times out this thing tonight!
#3635
Car: check
Engine: check
Transmission: check
You are taking a chance running full 1/4's with this set up.
If the column PSI_1 is fuel pressure there is a problem with it. From record 6645 through 6692, WOT, the MAP is about 95 KPa. Yet the fuel pressure (PSI_1) fluctuates between 21 and 30 psi.
However, I also graphed the PSI_1 after the above area when in decel. Records 6715 through 6765, it too is showing large fluctuations in fuel pressure. Between 13 and 25 psi.
Either there is really something wrong with the fuel delivery, or the pressure sensor isn't right.
RBob.
RBob.
#3636
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
RBob.
RBob.
#3637
I am becoming stumped with my idle. It will idle like a charm just sitting with no AC and fan not kicked on. Turn the AC on and it bogs and drops then comes back up to commanded idle with AC. Of course the fan turns on at the same time the way mines set up. I have a Taurus fan I just installed today and it is wired to the high speed. I will be changing that to low speed with high speed on a manual switch. When I am driving around fan/ac on, the car doesnt go straight to idle when I push the clutch in. It drops below idle then sometimes comes back up straight to commanded idle or it will swing up and down. Also, possibly the most annoying, when I am sitting still or driving slow speeds and turn the steering wheel the idle drops down and then comes back up.
I have a datalog showing the idle doing this. This is with no AC. Fan on but was the original single fan not the Taurus Fan. All I was doing was sitting in the drive and turning the wheel clock to clock with a pause to let the idle go back to normal between turns.
idle bog.txt
You can see the MAP go up. The Spark Advance raises some as the rpms go down. Along with a slight increase in the IAC steps. Any suggestions? To low of an idle for the cam?
idle bog.txt
#3638
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
RBob.
RBob.
#3639
Car: check
Engine: check
Transmission: check
Shouldn't be an issue with splitting the signal. Although the pressure sensor ground should be to the engine block.
The other thing to do is to place a small orifice in the line or fitting at the sensor inlet. I use a 1/32" (0.032") restriction to help dampen fuel pressures pulses. Usually use a piece of brass or aluminum about 3/16" long, drill the .032" hole and press it into the fitting.
RBob.
RBob.
#3640
Car: check
Engine: check
Transmission: check
There is also IAC bumps available for when the A/C and the fan turns on:
IAC - A/C on Bump Steps
IAC - Fan on Bump Steps
They can help prevent the RPM from dipping too low.
RBob.
#3641
Car: 1983 G20 Chevy
Transmission: 4L60
What you are seeing is somewhat normal. Even though CompCams states "strong idle", I guess that is relative. An idle RPM of 800 may be a bit low for that cam. Try an 850 RPM idle speed on a warm engine.
RBob.
RBob.
It has been a while since I looked through the EBL calibration. Does the EBL have IAC based AE compensation that is adjustable like some GM calibrations. I found years ago if the IAC opened and the MAP increased, sometimes the MAP increase would not trigger a delta MAP AE change and the engine would momentarily go lean and cause a stumble.
#3642
Car: check
Engine: check
Transmission: check
The EBL systems do have IAC AE when opening:
AE - IAC Opening Fuel
Mostly used for TBI sets ups (wet flow), but I've been known to use a small amount on port injection set ups.
RBob.
RBob.
#3643
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
How do.I scale the whole Ve table down ?y idle/ low loss numbers are,low.30's and top end ve is close to 100 with a few cells.at 100
#3645
RBob,
Just curious, but if Injector Opening time increases w FP, how does EBL, or any other system, modify the Injector Bias to account for that when using a VAFPR? Does it need to given that higher FP is occurring where IB is not as great a factor?
#3646
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Yeah, I'd think you would deal with the IB as a function of two things: lowest fuel pressure with the vAFPR (low map = low PW = high IB influence) and, I think this is more fool-proof, just a judgment on the shape of the VE table. Bathtub isn't right (not enough IB) and unrealistically low VE on low map isn't right either (too much IB).
#3647
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
I added a filter to the ebl preferences for my fuel pressure and it no longer jumps around like it did stays within 1.5psi or so
Also fixed a fuel line problem I've had since day one so that may gave helped the FP stability too
#3648
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
#3649
This is from DynamicEFI site:
Injector Compensations:
The purpose of injector compensation is to make up for the time it takes for an injector to open and then close. The proper values can be difficult to obtain, so many times they are guessed at based on results. Which in many cases works out OK.
In general terms the higher the fuel pressure the longer it takes for an injector to open. Increased fuel pressures are more prevalent on TBI systems. And as such should have the injector compensation values increased. Check the 5.4l calibration with the 80# injectors at 22 psi. Compare those values with some stock calibrations. That will give an idea of what values can be used.
With port injectors there is some information available for various injectors. If available then it is worth using to update the calibration.
#3650
