Tuning with the EBL
#701
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Tuning with the EBL
Here ya go, Was rooting around autometers site to get the p/n of the sender, I have the whole gauge
sender p/n 2246
guage and sender p/n 5763
RBob, I d/led the instuctions, I am a idiot , there are extra pins for a datlogger. It says for and autometer datalogger, but I will stick a meter on it and see. There is a signal out and a ground. Thanks!
sender p/n 2246
http://www.meas-spec.com/myMeas/down...sp/msp_600.pdf
There are other pressure transducer manufactures besides MSI, but it appears that most of them are chasing industrial or avionics applications - hence the prices are high sky! I am still trying to find an alternative, since I would like to monitor FP through EBL.
//RF
#702
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Autometer FP gauge datalogging
So, the pins for the datalogger must be for the latest incarnation of the autometer fuel press gauge. Mine has 10 pins, 4 and 10 are supposed to be the datalogging pins, but the are dead. No voltage on the data +, so I guess it's back to trying another way. I really want to run the guage AND datalog it in the EBL, not one or the other.
#703
Transmission: 2004R
Well, tried running the Fp gauge, and a wire into the ebl to log, and the ebl displays a fp reading, but it is like 7 psi too high, and jumps around a bit. looks like i am sol. I have to try and hook the ebl soley to the FP sender, RBob, you know offhand, or have the pinout offhand, so i can do this??
#704
Car: 75 Beast
Here is one possible pin out. Pressure sensor needs + 5 Volt reference supply to operate. You can get +5 volt from pin C14 which is used to supply reference voltage to TPS and MAP.
Ideally, it would have been nice to have A/D buffered reference voltage available as an output pin of J1 from EBL board. That way reference voltage would be the same as the one used with A/D IC for data acquisition. Rbob - perhaps +5 volt reference source output could be added to a next version of the EBL???
ECM I/O |-----|MSP-600 Sensor
Pin C14 |-----|Pin A (+5 volt reference) or red wire
EBL GND |-----|Pin B (Sensor Ground) or black wire
EBL Pin 0|-----|Pin C (Sensor Output) or white wire
//RF
#705
Transmission: 2004R
interesting, but can I still use the gauge with this set-up? I would think no because the gauge has a 12v input and ground, then the 5 volt output to the sensor. This is a great way to hook up just the sensor for the ebl though. Thanks.
#706
Car: 75 Beast
IMHO you should be able to use your gauge in parallel with EBL input. Rbob what is the input impedance of EBL A/D channel??? My guess, meter has its own 5 Vdc reference voltage which is used with pressure sensor. Only one + 5 volt line should be connected to avoid strange loops. Ground should be common to both EBL and meter.
If you really worried about loading you can build a little op-amp based unity gain buffer to make Y splitter so as to allow EBL and pressure gauge to see sensor simultaneously. This will de-couple EBL and meter input circuits. It is a very simple circuit straight out of the basic OP-amp hand book. Above requires electronics DIY'ing
//RF
//RF
#708
Car: check
Engine: check
Transmission: check
Can also try meauring the supply voltage at the transducer. Most are ratiometric with the output following the supply voltage. I believe it should be dead on at 5.0 volts.
RBob.
RBob.
#711
Car: '91 Chevy 1500
When I first start my truck in the morning, it "spits" some wet, black gunk out of the exhaust. The Open loop AFR table puts the AFR at around 13:1 - 14.5:1, though I'm not sure when it actually goes away. Does this seem too rich for open loop? Is there anything else that would cause this? I just replaced my cat a few months ago (not because it failed though), and I'm sure this isn't good for it.
#712
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
Hi, I have been working with the ebl equipment.
I have done several VE learns and about 5 datalogs. I have noticed that the BLM stays at 128 along with INT at 128 I have noticed that through datalogs and the WUD that it seems that I am not entering Closed Loop--I think---
I have Coolant temperatures of 170 and up and it still isn't entering closed loop and have been running for 30+ minutes. I looked at closed loop tables in TP and found everything seems normal.
CL- CTS THRESHOLD 46.25 Cel
199 to 798 Mv for 02 upp/low to go into CL
299 to 651 Mv for 02 upp/low to stay in CL
Please Help/ New to tuning Is there anything I am overlooking...
I have t
I have t
#713
Transmission: 2004R
Quote:
You should be able to run both the gauge & the EBL data logging. I wonder if Autometer changed the transducer that they have been using. Are there any names or number on the transducer?
RBob.
RBob.
If it is dead on 5vdc in, then it should be a fraction of that voltage out right, depending on the FP?
#714
Car: '91 Chevy 1500
Is it safe to say that if the DFCO is not right, the Learn VE will cut fuel when you're off of the gas? I notice that all of my lower MAP areas (below idle pretty much) are now lean, where the rest of the tune is spot on. I have never touched the DFCO.
#715
Car: check
Engine: check
Transmission: check
I'll have to pop the hood and take a look at the transducer being used. I got it used from my friends whom had it in his silverado SS. I'm tempted to buy the new one, with the datalog outputs on it.
RBob.
#716
Car: check
Engine: check
Transmission: check
I have t
I have t
RBob.
#717
Car: check
Engine: check
Transmission: check
Did these low MAP areas get a learned correction? I find it is difficult to get a low MAP value while below the engines idle speed. Normally the MAP increases in this case.
RBob.
#718
Car: '91 Chevy 1500
I'm sorry, I meant below where the MAP is at during idle.
Could DE cause it?
Should I just try to increase the VE table in the lower MAP areas and see if a learn changes them?
Could DE cause it?
#719
Car: check
Engine: check
Transmission: check
A lack of DE may be contributing to the lean VE. See what the O2 sensor is showing as you lift & the engine drops to idle. If it hangs rich causing the INT/BLM to drop add a little more.
RBob.
#720
Transmission: 2004R
Thanks RBob and Peter for that pin-out, if it stops raining I'll check it out. I'll keep you informed.
#721
Car: 1991 chevy C1500
Engine: 355 W/t-trim
Transmission: full manual t-350
Axle/Gears: 3.90 posi
when I change the displacment table from 305 to 350 my truck runs pig rich will hardly rev and blowing black smoke. i thought this only changed airflow calculations althow i'm probably wrong. What other tables will this affect I know it will affect all of them but what one should I be looking at? My engine is a fresh 355 am I missing something? Thank all of yall for your time and help
#722
Received my EBL Classic a couple of weeks ago, install and initial VE learn went so smooth compared to previous '7747 tail chasing.
First question: Is recommended 5-10 IAC's at idle in park or drive?
Second question: Do i still tune AE with PE disabled?
Thanks in advance
Thanks in advance
#723
Car: check
Engine: check
Transmission: check
The thing is, going from 305 to 350 isn't much of a change. And, it shouldn't affect the fueling to the extent you are seeing. It seems as though something else is wrong. Correct BIN? Does it do the SES blink at key-on, engine-off?
RBob.
Thanks in advance
Thanks in advance
I wouldn't tune AE with PE disabled. When doing it this way there can be too much AE once PE is re-enabled.
RBob.
#724
when I first got the ebl a year ago it did the same thing and thats what I thought that I was using wrong bin or something so I did't mess with it again then the engine blew and I'm now trying to get the new engine going. With the EBL bin and afew changes made(injector size, sa, idle speed) it runs, idles and revs perfect I can take that bin and only change the cid and its hard to start idles like crap and blows black smoke bad will hardly rev up it never cleans up.
#725
something else I see in the EBL info page that I should be using chip start c000->FFFF buffer 0000->3FFF I did not notice this I've been using chip 00F000->00FFFF buffer 000000->000FFF how much will this effect it has to causing problems
#726
Car: check
Engine: check
Transmission: check
using chip start C000->FFFF, buffer 0000->3FFF
Using the other set of values will have the calibration over writing the code.
RBob.
#727
Something else I was wondering how much will affect my tune with out a speedometer, I converted from 700r4 to a full manual turbo 350 and it is cable driven so the pcm will never see mph. I didn't notice anything with the old engine drove it this was for 4 or 5 months but the engine had 240,000 miles on it and it did all kind of weird stuff especialy and the supercharger install
#728
Car: check
Engine: check
Transmission: check
Better off with a VSS however, can be set up without one. You may be able to add an optical pickup unit to the back of the speedometer. Many of the full size vans used these (other trucks did too, just don't know which ones).
The optical pickup attaches with a screw to the speedo head. Wires go to a small buffer box. Then on to the ECM & cruise. Box is usually lime green and sometimes yellow.
RBob.
RBob.
#729
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
hey I just bought the ebl flash in the 8746. I have a few ?'s
1. Since it is an 8746 base can I use a VRFPR?
2. How can I get 1 seeing as i have searched and search and can't find a p/n?
3. The final question is... which ebl .bin do I use for my set up?
My set up. 350, 61# injectors, Comp xe268 hyd flat tap, performer intake, 305(casting 416 tpi)heads 1.94 intake 1.5 exhaust, walbro 255 fp, -5cc pistons, headman shorties true ual with h pipe and bullets, and a 2300 rpm stall infront of a 700r4.
I know how to use tuner pro jst fine, I havent installed ebl yet till I get some time.
Thanx
Thanx
#730
Car: check
Engine: check
Transmission: check
I gotcha' covered in the PM. Short answers:
1) yes
2) any EFI bypass FPR with a vacuum port (such as the aeromotive 13301)
3) the standard BIN, as it too if for a '416 headed engine
RBob.
1) yes
RBob.
#731
I've read this thread & first wanted to say thanks for all of the great info posted on this thread and on this board!
I installed the EBL last week into my 7746 ECM, setup the bin (EBL_F_TB.BIN) based on my engine, per the EBL docs provided with the and did a few VE learns based on the NB02, but since it seemed too slow I decided to wait on the install of the WB.
Last night I installed my LC-1 WB02 with the Moates O-meter and I was having some inconsistencies in the AFR reported on the Ometer and the Whatsupdisplay. using the prefernce setting of Innovative 05v the WUD shows about 13:1 AFR when the O-meter shows 12:1 when the controller is outputting 1.4v at the EBL analog input and O-meter. If I use the preference setting in WUD of WB0 they read within .1v. I checked the settings on the O-meter and it is setup to read 0v as 7.4:1 and 5v as 22.4:1 just as the LC-1 is supposed to output. should I keep the WB0 setting in the WUD preferences? I noticed that the O-meter has a bias factor that can adjust the reading if the AFR does not match what it "should" because of impedence loading or other effects. So how do I know what the WB02 "should" be reading? I checked the gound impedence at the meter and there is none.
One other thing, I couldn't get the VE learn to work off of the WB (only tried at Idle (around 650rpms), even though I let the CTS get above the 167d min for the VE learn. The idle is very rich, about 11:1 and has my cat glowing red hot (literally) by the time the engine reaches operating temps, is there a way to lean out the idle without using VE learn?
Any tips or help would be great! Thanks Rbob for the great product. I love how simple the EBL flash is to use! I just need alot more time to learn tuning and all of the options I can use. The self install was a piece of cake and took less than 1-hour start to finish.
You can see my engine/ build specs here:
https://www.thirdgen.org/forums/tbi/...r-383-tbi.html
#732
Car: 91 RS
[QUOTE=sixty;3756136]
One other thing, I couldn't get the VE learn to work off of the WB (only tried at Idle (around 650rpms), even though I let the CTS get above the 167d min for the VE learn. [QUOTE]
IIRC I set Closed loop-CTS Threshold to 151 to lock the blms for WB learn. It's been a while since I used the WB........in other words you don't want it going into closed loop.
#733
#734
Car: check
Engine: check
Transmission: check
sixty, for the LC-1 WB, program it for:
0V = 10:1
5V = 20:1
Then use the "Innovate(0-5V)" selection in the preferences dialog.
RBob.
0V = 10:1
5V = 20:1
RBob.
#735
#736
Car: check
Engine: check
Transmission: check
The short answer is yes. The WUD conversion is set up for the above values. A slightly longer answer is that 10:1 is at the bottom range of the sensor. As that AFR is approached (from above) the sensor output goes flat. Then at the high end (20:1), engines won't run at that AFR.
Keeping a narrower range allows better resolution in the ADC converter.
It is interesting that the LC-1 default values have changed. In the past it was 1 V = 10:1, and 2 V = 20:1. This was so folks could use a DVM to observe the AFR.
RBob.
RBob.
#737
Thanks for the long explanation. I figured that AFR scale had changed on the LC-1 and that is why the reported AFR didn't match, when the voltage was identical at both the meter and the EBL.
If I can ever get the collector to seal on the passenger side I could move on to tuning!
#738
#739
Car: '91 Chevy 1500
Just for kicks and grins I decided to set my open loop AFR table to 14.4 in every cell (since I am running OL) and then did a VE learn with an emulator. After driving around for about a half hour I realized that the learn was not bringing the AFR's down to 14.4 like I assumed would have happened (for the most part). I figured my WB could be off, but even adjusting the table down to 12.0 still had me reading high 13's. I have my PE AFR set to 12.3 and that seems to be accurate. Any idea why? I was going to check and see what Logworks reported, but I can't find the damn cable.
#740
Car: check
Engine: check
Transmission: check
For a VE Learn based on a WB, the commanded AFR is compared to the WB reported AFR. Corrections are based on the difference.
Do a Analysis Dump Log and view the .ebl file. The column labeled AFR is the commanded, the column labeled WB is the reported WB value. See if there are areas where they match, or if the WB value is lower then the AFR value.
Easy for this to happen if there is a too much AE. That will drive down the AFR in the exhaust which causes a richer then normal WB AFR to be reported. And the correction evens out when that is included with the time that the WB AFR is a little leaner then the commanded.
On the VE display any point that has a '.' doesn't have enough data to make a correction. It can also help to set the smoothing factor low or even off. This is when there are only a few data points that have a correction made to them.
For good VE learns, push the gas pedal then hold it. Constant pedal movement is bad for learning.
Are you are running the EmUtility with an Ostrich?
RBob.
RBob.
#741
Car: '91 Chevy 1500
The problem I'm having is that the commanded AFR is richer than what's being reported, so AE wouldn't have anything to with it in this case, right? There are also no exhaust leaks. I think I have my smoothing factor set to 8, so I will try setting it to 0. I'm running the Autoprom as an emulator for the learns.
#743
My rings are fine, but I have a big leak at the balancer, throwing ALOT of oil directly on to the exhaust, causing lots of blue smoke at rpm's above 4k. I replaced the balancer seal & it didn't help so I ordered a new balancer & aluminum timing cover on Ebay. Hopefully that should fix it.
As far as tuning, my VE and spark maps are in pretty good shape and the engine pull like a beast, pretty close to the commanded AFR. I REALLY need to get this oil leak figured out so I can get back to tuning, this EBL makes tuning easy, even fun.
The reason I thought it might be rings, was that I had a new cheap ebay billet distributor & I was getting oil being pushed up the shaft & out the reluctor. with that leak and the balancer leak, I thought it might be excess crankcase pressure. I reinstalled the factory distributor & the leak went away.
#744
Car: check
Engine: check
Transmission: check
Use a short 3/8 bolt, flat washer and some sealant (PST, Permatex non-hardening, etc) to plug the hole.
When this leaks it sprays oil all over the front and down the passenger side of the engine.
RBob.
#745
Thanks for the reply, I'll definately check this out as it make sense. Is it possible to access this bolt with stock TBI serpentine brackets in place? I think i know the bolt you are refering to & it is used to bolt the serpentine bracket in place. This could save me ALOT of work!
I actually got under the truck while my wife revved it and all I could see was that oil was somehow getting on the balancer & spraying all over. I'll let you know what I discover.
Thanks!
Thanks!
#746
It looks like RBob got it. For some stupid reason, I totally omitted the upper bolt. I didn't have a chance to install a bolt last night (picked up a bandsaw on craigslist), but I will tonight.
Thanks RBOB, I owe you a beer!
#747
Re: Tuning with the EBL- NAlpha-
Did the closed +unpluged IAC log + entered values in the KPa vs RPM & TPS table.. not enough fuel to run on at lower rpm,(idle),does the entire 400 row need to be max KPa? (Around here 88). Am running OL. Thanks, Val
#748
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
High load Async vs Sync.
DC for sync should be kept under 80-85%. As I understand it, async needs to be 90-95%. I'm assuming sync is easier to tune because async has such a narrow window. Is this correct?
What would be the case where high load async would work best or be necessary?
Concerning 10% ethanol; 14.1 for closed loop is mentioned. What items need to be changed to achieve 14.1 (Other than "Stoich AFR")?
#749
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
