emulation table update
Car: Camaro 2000
Engine: ZZ4, SD730
Transmission: TH 400
Hi, I have an emulation question.
ECM:7730
Bin:S_AUJP_v3
Definition:Super_8dm2.ecu
Engine:ZZ4 350 with TPI 92
Moates APUI ,Tuner Pro RT
When i emulate everything work's, I can make change for constant and flag it will update.
EXCEPT for the table/fonction, it will not update.
So i can't change VE table.
I have a AFR WB meter, i change VE Table, AFR don't change, i click update and the green update progression bar dont work, but it will update with flag and constant not with table/fonction ???
Checksum disable or enable....same thing.
Help!
ECM:7730
Bin:S_AUJP_v3
Help!
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
Sounds like this thread might apply to you, too....?
https://www.thirdgen.org/forums/diy-...sues-58-a.html
Car: Camaro 2000
Engine: ZZ4, SD730
Like you wrote...
"table updates would only take place when you manually enter each cell value"
I tried and it work manualy, will it be fix in a future version?
ALDL, is very demanding on my old laptop (300 or 400 Mhz) so i dont use it , instead i have a old GM TECH1 scanner that i use.
I have fatal crash too sometimes.
I will try to tune VE table tomorow....with AFR WB.
Thank for debuging!
Thank for debuging!
Car: Camaro 2000
Engine: ZZ4, SD730
well, even manually any change made to the ve table dont seem to work...
it will update but do nothing on AFR in emulation.
Now i practice on a 2.8 liter celebrity, because our 350 have a big cam, very rough idle... so i want to get use with tuner pro RT on a more gentle engine. For the 2.8l 7730 ecm i read the prom with apui, 6D xdf. I can change constant and i see the changes. But nothing happen when i work on table/fonction, i put it open loop and try to lean it or richen it, even putting
+100 or -100 on VE TAbles nothing....AFR WB always stay at 10,8:1. for the V6 there is idle Ve Table and Main VE table ,try change both, even save the bin and open it to emulate...nothing. I want to see the AFR change....???
2012sergen11
10-13-2015 07:38 PM
