Tunerpro R/T - won't connect with aldl
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Mangus,
Is there something really obvious I'm missing with getting Tunerpro R/T to data log aldl over a USB convertor? My setup works with my own software (for uploading and downloading bins over the aldl port), but I can't get the aldl logging to work in tuner pro...
ftdi chip set in the usb convertor
8Hz target
com5:
I can see the lights flashing on the convertor when there is tx/rx data. Is there a way to debug this easier on my end? Such as viewing the raw packet recieved?
EdB
8Hz target
com5:
EdB
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I was wondering too. My USB to RS-232 converter works fine with TP4.13 connected to my homebuilt emulator and the xtronics emulator at the same time I have my true RS-232 port connected to the ALDL cable. It all works fine.
If I swap the USB converter to the ALDL cable and true RS-232 connector to the emulator, then only the emulator will work. The ALDL cable will not work with the USB converter. Anyway, same problem that MonteCarSlow has.
Thanks,
Junk
Thanks,
Junk
Hotrodboba400
12-10-2019 07:07 PM
