7730 $58 and manual tranny: shift light?
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I just thought it would be cool to get the dash shift light to work with the $58bin now that I have a T5. search turned up nothing.
Car originally had a 305 TBI w/auto...
Then a TPI 355 (Holley Commander 950) w/auto
now a 7730 ecu/harness with $58bin and a T5.
(harness and ecu are from 91 z28 350 w/auto)
The .xdf I'm using for the $58 in TunerPro doesn't have tables/constants for shift light logic. Is there an editor or .xdf that includes the shift light logic.
I checked the flag for manual transmission, but i'm petty sure the shift light is set not to come on untill 6375 rpm. I don't think there were any syty's with manual trannies from the factory.
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
Get this .bin editor for $58 http://home.swbell.net/loeryder/prom.html It will allow you to change the shift light parameters to get it working. The turbo sunbird and turbo grand am used the same $58 code with a 4cyl and a 5 speed manual, but they didn't use this feature either. A little playing around will get it working though.
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Which pin on the ECM are you using for the shift light? I didn't see a pin for it on any of the schematics.
From a low level code point of view. The BBZB $58 differs from the $8F code. Maybe they work the same from a high level. Side by side they look different in a few places.
Which pin? thats a good question. I haven't actually hooked up the battery since swaping in the 7730 harness. I don't even know if the shift light will work. I was just hoping if I enabled it in the bin, i'd be one step closer to getting it to work.
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
The shift light shares the TCC pin (F4). As long as your shift light is wired like the TCC where the ECM is pulling the output "low", you should be fine.
I just started taking a look at the $8F code as compared to the $58, too. I did notice the wastegate control between $58 and $8F are *identical*. Haven't checked the TCC/shift light logic, though.
Car: 1991 Z28
1981TTA is correct the pin used for the lockup converter is used as the shift light when MT is enabled.
thanks a lot! thats good to know. Now, in theory, the shift light should work properly when I get everything together. School has really been cramping my "car working on" time. When I finnally try it out i'll post back to say how its working. I adjusted the N/V ratio for my trany and gears. I added the N/V ratio calculator to my ever growing excel sheet:
https://jshare.johnshopkins.edu/asch...calculator.xls
if it asks for a password just click cancel.
1992 Trans Am
05-10-2023 07:19 PM
