Moates Ostrich
Car: 91' Camaro RS
Engine: LO3 305
Transmission: Built 700R-4
Moates Ostrich
hey guys whats up? im building a 350 tpi for my 91RS and i was wondering how well the Moates Ostrich worked. im VERY new to tuning and i need to know if it will be simple enough for me to work with on my cars. before i tune the camaro i will try and use my beretta as a practice car just so i dont screw up the camaro later ha ha. and if you have any suggestion for an ECU that works best with TPI let me know also! Thanks!! you rock!
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Use a 730 for your 91, and I really like my Ostrich - much quicker than always burning proms.
Car: 91' Camaro RS
Engine: LO3 305
from my understanding the ostrich plugs into a special chip you solder into your ECU and then you can "burn" the chip that plugs into that one.....http://www.moates.net/product_info.php?products_id=57
thats the link to the site. what is a 730 ECU???
No, the Ostrich does not burn chips. You will probably eventually want a burner like the Moates Flash-n-Burn, or just go the Autoprom to begin with if you have the extra $$ laying around. I started with a FnB, then got tired of the constant chip burning and bought the Ostrich last year. Haven't burned a chip for my car since, I'm running the Ostrich all the time.
Car: 91' Camaro RS
Engine: LO3 305
so are you saying the ostrich just replaces the chip? and you have to leave it plugged in?
Yep. No soldering is required either on the 730 ECM. You have to have the Moates adapter (G1 I think). You unplug your memcal, put it on the adapter, plug the Ostrich into the adapter, and plug the adapter into the ECM where the memcal used to be. The Ostrich has it's own 30 year or so life battery, so it retains your programming changes.
Check out www.moates.net, all these questions are answered there.
Car: 91' Camaro RS
Engine: LO3 305
sweet!! so its kinda like a stand alone fuel injection system.....only better!! and what did the 730 ECU come in?? and whats so special about it?
Check the tech articles, all I know for sure is the 91-92 (speed density) cars, but pretty sure the Ostrich will work on a lot of other years as well.....
Car: 91 RS
UltRoadWarrior9
04-28-2020 10:39 PM
