$58 LC-1 wideband
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
$58 LC-1 wideband
how would i get the LC-1 wideband to work on the stock bbzb-1580 bin and tunerpro?
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
IIRC, 1981TTA posted a patch (or bin) with the mask called $59 that had his WB stuff in there. I believe that is what he runs. Check the usual places for it, I remember seeing it somewhere.
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
If you're interested in $59, you can find it on Moates' site. It's under the "Custom Binaries" section named "$59_05202005.zip". (However, only "_05202005.zip" shows up on the screen......)
Let me know if you need to have your calibration moved from BZBB to $59. I can give you a hand with that.
Car: 1986 Camaro SC
i do have the $59 and for some reason it doesnt match the stock bbzb, the esc settings are different and a few others, i had a hard time getting the $58 code to work on my car, i'm back to $8d now, i would like to get the $58 to work, i dont think the iac is working properly neither, which no one has a definate answer on which way to wire it
efiguy
09-27-2015 01:30 PM
